2005 PT Cruiser won't start -- wait two hours and starts fine
Old 12 Sep 2011, 07:48 am
Default 2005 PT Cruiser won't start -- wait two hours and starts fine
Hi, I'm new to the forum and have a 2005 PT Cruiser turbo convertible. Periodically, we will drive it to church or the store and when we return, it won't turn over. The lights work and the battery is fine. We can wait two to four hours and it will start fine with no problems. I suspect the security system but don't know how to fix it. Any help or suggestions would be greatly appreciated. Thanks
Old 12 Sep 2011, 03:02 pm
Default Re: 2005 PT Cruiser won't start -- wait two hours and starts fine
Just because the lights, radio horn and other accessories work, doesn't mean the battery is good. They all take next to nothing to operate whereas the starter needs just about the full 12 volts. Take the car to one of the better auto shops and most of them will test the battery and charging system for free.
Old 13 Sep 2011, 04:58 pm
Your problem is not the battery. If the battery were weak, you wouldn't be able to start it a few hours later. Batteries don't just recharge themselves as they sit.
This sounds more likely to be a fuel pump problem. Fuel pumps often start acting up when warm (after driving), and working again after the car has cooled for a few hours.
-Chris
Old 13 Sep 2011, 08:13 pm
You said it won't turn over which means it won't crank at all. If it turns over but won't start perhaps a fuel pump or skim problem.
If it truly won't turn over, do you hear a slight single click? This could be an indication your starter is bad. If you hear nothing at all, could be a starter relay issue, ignition switch, aftermarket alarm with starter kill, etc.
Please clarify if it's turning over or not when it won't start.
Old 13 Sep 2011, 09:25 pm
I know the battery is good because it still won't crank when I use jumper cables. It does not turn over at all. There is no click and I've checked the connections and cables. I've never put an aftermarket alarm in the car and we've had it since it was new. It is one of the first ones manufactured. The last time it happened was several months ago and its now happened twice in the last week. I've called Chrysler and the technician I talked to hasn't heard of this problem. It never does it when it goes in for service. Its hard to analyze because it doesn't happen often and usually doesn't show up after an incident for months.
Old 13 Sep 2011, 09:26 pm
Oh, and I really appreciate all of you taking the time to answer and help me figure this out.
Old 14 Sep 2011, 04:37 am
If it's not turning over at all, that rules out alot of things. The first two things that come to mind are the starter relay and the wire to the starter solenoid has a bad connection; both are fairly common.
The best way would be to use a test light at the starter relay the next time it happens. That would tell you if it were getting a signal from the ignition switch and sending it to the starter and you could better isolate the problem.
You could also try swapping the starter relay with another one. Also try taking the solenoid wire off, wire brushing the tab, and use some contact cleaner on the connector and see if the problem ever occurrs again.
Old 14 Sep 2011, 03:46 pm
I'm guessing the ignition switch - try pushing in on the key when you try to start it.
Old 28 Nov 2011, 12:30 pm
I'm having a similar 'no start' problem with an 2004 PT 2.4L Auto. At first it would restart after disconnecting/reconnecting battery terminals. Now (3 weeks later) it takes 2 hours and sometimes longer before it will start. The battery has been tested, the starter works, all relays are working, no security issue (according to dealer the coded key feature will shut the engine down after running for a few seconds if the key code doesn't match), all power connections to the starting circuit cleaned. There are no error codes present at the odometer or code reader.
When the system is in a no start mode the starter relay does not 'click'. When it's in start mode the starter relay 'clicks' and everything runs as per normal. I've swapped the relay with a known good one - same outcome. All relays 'click' when activated. There is a full 1 second delay from when the key is turned to when the starter fires up (this seems new)
Being in the computer field this reminds me of an electrical intermittent failure due to a slight crack in a component that expands (breaks connection) when heated up. This could explain the reason for a no start when the vehicle is hot (normal) and the start when it's cool. Example: I was out this morning and the vehicle successfully started 3 separate times (within 1 hour) and each time the operating temperature was below normal and had not reached full operating temperature.
My most recent mechanic suggested replacing the PCM, I'm just not sure that is the problem and don't want to spend a fortune replacing all electrical parts.
Thanks for any ideas feedback!
Old 28 Nov 2011, 12:44 pm
cruserdad1976's Avatar
not sure but how about the multi funcition switch?????
2002 PT Cruiser fine till getting timing done deryk Tech & Performance Forum 19 06 Sep 2011 01:58 pm
2001 PT Cruiser starts then shuts off after a few seconds. jdell408 Tech & Performance Forum 4 22 Aug 2011 10:27 pm
2002 Pt Cruiser starts and then shuts off! please help vic001 General PT Cruiser Discussions 0 18 Apr 2011 12:35 pm
2001 PT - Starts, runs, stalls...won't start silver7 Tech & Performance Forum 12 20 Sep 2010 03:11 pm
2005 pt cruiser no start fusion1620 Tech & Performance Forum 1 17 Jun 2010 05:57 am
