Lower motor mount bolt specs (missing bolts)
Old 17 Sep 2011, 03:41 pm
Default Lower motor mount bolt specs (missing bolts)
Hey everybody, finally quit lurking and actually registered because I have a question I cold not find the answer to here! I am rebuilding a wrecked PT, and its done, with the exception of the lower motor mount. The mount was removed and the bolts lost thanks to my previous mechanic.
What bolts do I use to replace them? I cannot find the specs for the actual bolts anywhere. Thanks for any help.
Old 17 Sep 2011, 03:51 pm
Default Re: Lower motor mount bolt specs (missing bolts)
I would check with a dealer and try to get them. The rearward bolt is more of a stud that is also a mounting bolt/point for another strut.
Old 17 Sep 2011, 05:28 pm
Just took another look to make sure I have the front bracket the mount bolts on to (transmission bracket?) and I do have the rear bolt that the pencil strut is attached to, just not the front bolt. A dealership might be able to help if I would have called today, but I didn't, and I need to get this on before Monday. Im thinking to buy a selection of bolts and just see which one fits. Length is no issue, so I just need the correct threads. Off to Lowes I guess.
Timing Repair Project - Bolt Torque Specs bmw525it Tech & Performance Forum 6 06 Oct 2014 05:50 pm
Motor Mount (upper strut) bolts. mdfrodolives Tech & Performance Forum 12 07 May 2011 02:12 am
Missing bolts! Musicman General Turbo Discussions 2 25 May 2010 05:22 pm
bolt torque specs?? GTCruiser2003 General Turbo Discussions 1 30 Mar 2004 04:33 pm
WGA mounting bolts torque specs??? rice_killing_GT General Turbo Discussions 2 07 Mar 2004 06:44 pm
