02 wont start
Old 18 Sep 2011, 12:01 pm
Default 02 wont start
key is on have power hear everthing turn on but car wont start. dont even hear a clicking sound when u turn the key any help plz
Old 18 Sep 2011, 12:46 pm
Default Re: 02 wont start
What voltage do you have at the battery?
Old 19 Sep 2011, 11:00 pm
voltage is normal i have to jump the starter with a screwdriver
Old 20 Sep 2011, 06:41 am
What is "normal"? The PT needs at least 11.8 volts to turn over the engine. If you have that, and still won't turn over you need to check to see if all the volts are getting to the starter. Take off and clean all the cables from the battery and starter. If that's not your problem, the starter or starter solenoid should be your problem. I'm told you can't buy the solenoid by itself.
Old 20 Sep 2011, 08:15 am
If you're jumping the starter with a screwdriver and getting it to start, you likely have a problem with your starter relay or ignition switch. Try swapping relays and if still won't crank, take a test light to where the relay plugs in and see if you're getting a signal from the igntion switch. You can also see if it will start in neutral.
If this is a stick however, first thing I would try is jumping the clutch pedal switch.
Old 20 Sep 2011, 11:44 pm
oops im srry it is a stick i will check the relays tonight jus bought the tester light so being on for the next couple of hours
02 PT WONT START sgtwsky Tech & Performance Forum 2 15 Jan 2014 05:39 pm
02 wont start Sfos Tech & Performance Forum 15 10 Jan 2014 05:46 pm
04 pt wont start penstar66 General PT Cruiser Discussions 6 01 Sep 2010 02:27 am
02 pt wont start J_GEISLER Tech & Performance Forum 3 19 Jun 2010 10:39 pm
Wont start now? morrisbeer General PT Cruiser Discussions 2 21 Feb 2009 10:14 pm
