Wheel Bearings not just a PT issue!!
Old 20 Sep 2011, 07:44 pm
compdr59's Avatar
Default Wheel Bearings not just a PT issue!!
Don't just blame Chrysler for the issues many of us have with wheel bearing failing prematurely. My baby (2nd one owned) has 104k and it's time for them again, or at least the driver's side.
Additionally, my 2009 Nissan Altima starting making noise at 17K. At first the dealer blamed the tires. The dealer finally changed one bearing today on the last day of the factory warranty at 20K. You think you buy a brand new Japanese car and you expect it to be trouble free, that's obviously not the case.
It's hit or miss with many parts being imported from all over the world. My first PT never required wheel bearings, but it did require control arm bushings and a cooling fan.
Original Owner 135k
Old 21 Sep 2011, 06:44 am
Default Re: Wheel Bearings not just a PT issue!!
Funny - I've never replaced a wheel bearing in any car I owned, but I did need 3 starters and 2 alternators....
Some things don't have predictable lifespans...
Old 21 Sep 2011, 09:29 am
I've had to replace wheel bearings a couple of times but so far so good on the PT. My others were from running in lots and lots of water....eventually all those seals start to go and you get water in the bearing grease which turns to rust which causes friction which breaks down the bearings and roller ways....
Old 21 Sep 2011, 10:18 am
cruserdad1976's Avatar
i have a OLD AC Track Loader and we had to pull the drount sproket off beacuse the bearings were GONE ended up having the axel made(its to old to find a replacement so off to the machine shop got it remade got a new set of tinks and got it all put back togther hard to belive the bearings coudl actually EAT up a AXEL btu OMG they did
Old 21 Sep 2011, 11:48 am
I think it has a lot to do with how you drive as well...if you run the Cruiser like a go-cart you are going to be putting a whole lot more force on the beraings compared to granny driving.
Old 21 Sep 2011, 11:50 am
True, and I drive it like I stole it yet my bearings are still good to go....
Old 21 Sep 2011, 12:52 pm
UptownSport's Avatar
Guy's were breaking HUBS during circle track!!!
Most drag racers have upgraded to the Early PT hubs, but dunno 'bout circle trackers!
Old 21 Sep 2011, 06:34 pm
Mikadoo's Avatar
You will find most of the problem for premature bearing failure is because of the offset of the rim. Too much offset puts a lot of pressure on the bearing.
Think of it like hanging a weight off the end of your finger then slide that weight in towards the center and you'll find it much easier to hold up.
Bye Bye wheel bearings turbomangt General Turbo Discussions 71 18 Jun 2017 08:32 pm
How many front wheel bearings? scrisp2 Wheels, Tires, Suspension 0 22 Mar 2010 11:24 am
How can you tell if you need new wheel bearings??? Ironman Tech & Performance Forum 5 09 Dec 2009 09:29 pm
Wheel Bearings dadart Wheels, Tires, Suspension 5 28 Jan 2009 01:00 pm
Bad wheel bearings VandyCruiser Wheels, Tires, Suspension 6 06 Sep 2007 09:08 am
