The engine has 75 miles on it after the rebuild. I get a noise during acceleration that can be heard when I give the car some gas. It is present in park or Drive.
Car drives fine but I suspect that it may have some kind of exhaust leak. Almost sounds like my old go-cart. What could this be? I did have a cracked exhaust manifold and replaced it last week. Also replaced EGR gaskets. All parts are tight and I do not feel any leaks there. The video is not the best but you can here the noise.
2001 PT Cruiser, Silver, Base, 2.4 ltr. |
Have you checked the flexible part of the exhaust, between the cat and the manifold
I noticed that it had a small bit of free play while I was moving the tubing to instal the new manifold. It was only a small amount and could barely be pushed with my hands, I will try to check it tomorrow evening.
Thanks
My wife's 01 was leaking from there and had to change it.
I'll put it up on ramps tomorrow and see if I can feel a leak there. Thanks again.
Sounds more like a leak on the intake side to me ... if you mean the pffffftt sound when you press the pedal? Maybe check the airbox is tight and actually has a filter in there...
I cannot tighten the intake more than it already is. I used new gaskets and do not see a twist in them, the intake manifold does not look cracked. There is a filter in my airbox.....
I put her up on ramps this evening and started the car. After I got under the car I flexed the exhaust pipe and could not tell a difference. I also places some paper around the flex adapter to see if anything was leaking out.
I found nothing. Maybe i'll run it by an exhaust shop Saturday, problem being that the closest one is 35 miles away.....should I drive it there or just go ahead and replace the pipe? Where is the best place to get the pipe at a low cost? Ebay only seems to have the pipes for turbos.
The EGR valve was not tight enough. I installed a new gasket and tighened it. Issue solved.
Thanks for getting back.
Thread Tools | |
Display Modes | |
Help with noise? | iCruz | Wheels, Tires, Suspension | 6 | 17 Jun 2011 11:26 pm |
Noise!! please help!! lol | PtTurbo04 | General Turbo Discussions | 6 | 14 Dec 2010 06:46 pm |
bad bad noise!!! | woodmansnj | Tech & Performance Forum | 7 | 20 Sep 2009 08:24 pm |
Welcome to Name that Noise | TexasPriest | Tech & Performance Forum | 14 | 25 Jun 2009 03:19 pm |
Road noise / exhaust noise in the car. | jackatg450 | Tech & Performance Forum | 3 | 21 Jul 2004 10:55 pm |
