2003 PT Cruiser died while driving
Old 23 Sep 2011, 07:48 am
tlm tlm is offline
Default 2003 PT Cruiser died while driving
While I was driving down the road, my car's check engine light came on and then the car just died immediately after. It sounds like the engine is turning over, but there is no clicking sound when the key is turned. The lights inside dim when trying to start the car.
I checked for fault codes and the car came up with: P 0016, P 0522, P 0344 and P 0068.
I'm hoping that it is something I can fix at home.
Any help is extremely appreciated.
Old 23 Sep 2011, 08:13 am
Default Re: 2003 PT Cruiser died while driving
What kind of mileage do your have on your PT? Anywhere near 100K could mean that the timing belt snapped. You have to many different codes but 2 of them (P0016, P0344) are the ones you might get when the belt breaks. NO, it's not something that YOU want to try at home.
Old 23 Sep 2011, 08:49 am
tlm tlm is offline
It has a little over 134k. We changed the timing belt last year, but I'm not sure how long they are supposed to last.
I forgot to add that when the car died, it didn't make a noise. It just turned off.
Old 23 Sep 2011, 09:13 am
Belts should last for 100K so that's probably not your problem.
Two of the codes yo pulled have to do with either the Camshaft or Crankshaft sensors. Either one of them will bring the car to a halt without warning. Happened to me. Unless you just want to change both sensors (use only genuine Chrysler parts), I suggest you find someone with a scanner to pinpoint exactly what's wrong.
Old 23 Sep 2011, 10:29 am
tlm tlm is offline
Thank you so much for all of you help.
Old 24 Sep 2011, 01:45 pm
tlm tlm is offline
Well I think we found the problem. There is oil pooling in the far left plug well. I'm thinking we may need to get a new valve cover gasket, spark plugs, and wire set. The other wells seem to be dry, but that one is filled with oil.
Old 24 Sep 2011, 01:47 pm
Each spark plug hole has it's own gasket also. Change them.
Tags
2003 cruiser, fault code
2001 Died while driving compguy Tech & Performance Forum 3 07 Aug 2013 11:43 am
Engine died while driving, Blown ASD fuse & VERY Hot MyCruiserHatesMe Tech & Performance Forum 11 10 Aug 2011 08:50 am
2003 overheating when driving at low speed eryncourtney Tech & Performance Forum 3 12 Jul 2011 07:33 pm
Cruiser Died MomsCruser Tech & Performance Forum 15 13 Feb 2011 12:46 am
2003 PT Died on the road.... trerrick Tech & Performance Forum 2 29 Dec 2009 06:49 am
