tranny code P0605
Old 23 Sep 2011, 08:55 pm
Default tranny code P0605
greetings - great forum
i had a cruiser that would not shift out of first. speedometer worked fine.
in looking thru the posts, i felt fairly confident about about diagnosing a P0605 code as a bad TCM. i checked the ground pins in the connector for continuity - OK. i replaced the TCM relay just in case - OK. nothing else looked suspicious. i bought a dealer TCM, which surprisingly was a rebuilt, installed it, and the cruiser shifted thru all gear ranges. speedometer was erratic but functional. i "drove" it to the dealer for quick-learn and pinion programming thinking i had the problem whipped. word i get from the dealer is they can't make the TCM accept the programming procedures and they have to look deeper. dealers don't let you talk to the tech. does anybody have any thoughts? should i be suspicious?
thanks in advance.
P0605 Bentron General PT Cruiser Discussions 11 09 Aug 2011 03:58 am
srt 4 tranny mattsptgt Tech & Performance Forum 3 03 May 2011 07:19 pm
When my tranny goes... ucantcme Tech & Performance Forum 1 06 Oct 2008 05:17 am
i think tranny is bad g00zor General Turbo Discussions 9 08 Jan 2007 07:29 pm
Tranny ? umaxman Tech & Performance Forum 29 30 Sep 2006 12:56 am
