BG Universal Synthetic ATF
Old 25 Sep 2011, 07:11 pm
Default BG Universal Synthetic ATF
Has anyone used BG Universal Synthetic ATF in their PT?
I had a transmission flush done at an ex-Chrysler dealership and asked twice before getting it done if they used Chrysler ATF-4 when they did it and they said yes. When I went to pick up the car, I saw that the invoice said BG universal synthetic ATF. They claim it is the same thing plus they have a $1000 36,000 mile warranty on any transmission problems.
Should I be worried about the fluid or is it a valid replacement for Mopar ATF-4?
Old 25 Sep 2011, 07:36 pm
Default Re: BG Universal Synthetic ATF
I would think as long as it's ATF that it would be OK. I had mine flushed with synthetic with the BG machine from the Chrysler dealer. Hopefully they knew what they were doing. The fluid came in a sealed plastic bag-like container inside a cardboard box. Only had ATF Synthetic written on the outside. So you should be OK.
It's 49K since I had it done and it's running good. Time to do it again.
Old 25 Sep 2011, 09:27 pm
mdfrodolives's Avatar
Isn't there a list here of approved ATF's for our PT's? If not, Google in "Chrysler Approved ATF Automatic Transmission Fluid".
Tim
Old 25 Sep 2011, 09:30 pm
yes Tim, I put the sticky up myself.
Licensed ATF+4 Brand Names
Old 25 Sep 2011, 11:17 pm
Hmmmm...doesn't show BG....
Old 26 Sep 2011, 12:21 pm
Yes, I had found that list and saw that BG was not on it. I did send a contact request using the link there to ask if it was compatible, but have not recieved anything back.
First impressions after the change is that my mileage seems to be less, instead of 25-26 on the highway, only 21 on the last fillup, not conclusive yet, I have only run one complete tankfull since the change. Also, it does seem to be much easier to get the tires to break loose if I floor it at a stop.
Old 26 Sep 2011, 12:28 pm
cruserdad1976's Avatar
has to be a turbo
Old 26 Sep 2011, 01:07 pm
Originally Posted by cruserdad1976 View Post
has to be a turbo
2001 NA
Old 26 Sep 2011, 01:38 pm
well my 06 NA wont spin the tires unless you knwo its Ice snow or maybe on a really good day just super wet
Old 16 Apr 2012, 08:43 am
After 6 months, I finally got a response back from Chrysler on my question on if BG transmission fluid is compatible with the PT's transmission
Thank you for your contact. My apologies for the delay in responding. BG 312 BG Universal Synthetic ATF is not a licensed product and, therefore, not recommended for use in Chrysler transmissions. Although it has been several months, our recommendation would be to change your ATF fluid to ATF+4 for long-term transmission protection and performance. In most cases, inappropriate transmission fluids will not cause immediate catastrophic failure but will cause on-going degradation, shortening the life and performance of the transmission.
ATF+4 is a unique formulation that has been designed specifically to meet the exacting requirements of Chrysler transmissions. The fluid has gone through an extensive developmental and testing process, including more than one million miles of severe field testing. It is a high performance, synthetic fluid that provides significant reduction in component wear, superior temperature performance, consistent shift quality, and exceptional friction modifying properties.
Only licensed ATF+4 products (with "ATF+4" as part of the brand name and a valid license number on the back of the label) contain the unique formulation. Other look-alike products that claim to be suitable for use in Chrysler transmissions have not gone through Chrysler's rigorous testing process, are not monitored for quality, and are not approved or recommended for use in Chrysler transmissions.
Thank you for your interest in properly caring for your Chrysler vehicle. I hope this provides you with the information you need. If you have any questions, please contact me.
Sincerely,
The Center For Quality Assurance
4800 James Savage Rd.
Midland, MI 48642 USA
Phone: +1 ....
Fax: +1 ....
Email: ....
I have already had the transmission fluid changed to Mopar fluid, since I noticed the pan was leaking when I changed the oil last time. I had to drive to the next county as Chrysler closed all of the dealers within ~30 miles of me.
Re: Universal wheels rt66pt Wheels, Tires, Suspension 1 07 May 2010 10:37 am
Universal Sunroof. Raises up & can be removed! Wicked_PT Classifieds: For Sale/Trade 2 12 Jul 2006 07:24 pm
K&N 3inch universal midnight03 Turbo Performance 0 21 Jun 2004 06:54 pm
