Engine Light
Old 26 Sep 2011, 10:41 am
Default Engine Light
I have a 2001 PT limited edition, it currently has 100,615 miles. While driving yesterday, the engine light came on. Everything on the car was running fine and all the gauges looked fine. I checked the oil and it was a little low, so added more. I haven't been able to check again to see if this solved the problem. But after a little investigation, I'm wondering if just being a little low on oil would cause this light to come on. I don't have an owners maual, we bought the car used and it didn't come with one, so we are kind of guessing at what the lights mean. Can anyone help? Thanks.
Old 26 Sep 2011, 10:44 am
cruserdad1976's Avatar
Default Re: Engine Light
well firsrt NO a little low on oil will not trip a code
Id to the key dance to see what the code is
There is a sticky telling you how to do it
Have you had the timing belt changed??? it wont throw a code but it will stop your car
Old 26 Sep 2011, 11:37 am
Error Codes
Old 26 Sep 2011, 12:31 pm
OR that works too
Old 26 Sep 2011, 01:45 pm
Thanks, hubby is gonna check codes when he gets home from work tonight. Just found out about that little trick today, hope it helps us out.
Old 27 Sep 2011, 12:32 pm
Ok, so I've got code P0551 power steering pressure sensor. How serious is this? Is the car still ok to drive? How fast does it need to be fixed? I only ask because I have a limited income and this car is my only transportation. Thanks.
Old 27 Sep 2011, 12:35 pm
They do go bad. You can probably get away with it for awhile. It's easy to swap switches but a VERY messy job. Yo can't get the old one out and the new one in without a bunch of fluid coming out.
Old 27 Sep 2011, 12:57 pm
Thanks Crewzin. I appreciate the help.
Old 27 Sep 2011, 01:25 pm
Not serious.
What you should do is check the PS reservoir and be sure fluid isn't low, and top it off if it is.
It takes ATF + 4 - I hear WalMart sells it.
Old 28 Sep 2011, 07:35 am
So, I found the switch at Autozone for $26.00. Will the hubby need any special tools or anything other than power steering fluid to complete the job? I truly appreciate the help.
2004 Engine misfire and flashing check engine light fg1911a1 General Turbo Discussions 15 26 Jul 2014 06:20 pm
Check engine light and battery light on tay2208 Tech & Performance Forum 2 27 Jul 2011 05:44 am
Dashboard goes crazy, check engine light,oil light...... jggarza3247 Tech & Performance Forum 2 10 Jul 2011 06:23 am
Check engine light: Amber Light: power loss dbleclk Turbo Performance 2 06 Jul 2011 06:12 am
Car Sometimes won't start (oil pressure light & Engine Light) gerardio Tech & Performance Forum 6 18 Jul 2008 08:22 am
