2 error codes at once
Old 29 Sep 2011, 11:36 am
Default 2 error codes at once
got
0522
0340
I've most of the threads on these two codes..I see how to xif the 0340 cam shaft
but I failed to see a how to on the Oil pressure 0522
anyhelp would be great..
the 2003 PT is having trouble starting sometimes it takes 2-3 times to get it started...also these error codes are popping up..any ideas??
Old 29 Sep 2011, 11:47 am
Default Re: 2 error codes at once
It's the camshaft sensor that might be giving you the problems with starting. Although I have seen personally where the oil pressure sensor light was on and the car wouldn't start. When was the last time the plugs and wires were changed. They will make it hard to start if they need replacing.
Anyway. Only use Chrysler parts for anything electrical.
Old 29 Sep 2011, 12:28 pm
cruserdad1976's Avatar
have you checked the oil???ounds simple but you never klnow
Old 29 Sep 2011, 12:40 pm
yeah I checked the oil yesterday a tad low..I am getting an oil change soon..However the starting problem has been oing on for a bit now a couple months..the last big check up was about 2 years ago..replaced battery, spark plugs all that..
I will change that cam sensor auto zone is down the street..hopefully that will do it....
should I bother with the Oil pressure sensor first or the Cam sensor?
could it be the battery is going, thats why it's having trouble starting?? sometimes it fires up fine other times not so..
Old 29 Sep 2011, 12:42 pm
well im sure CREWZIN will agree but dont I repeat DO NOT go to auto zone for some syupid unknown reason the PT simply HATES after market sensore most of the time they wont even work and when they do it is for a short time I knwo the dealer is higher but on this part its about the best option
Old 29 Sep 2011, 12:43 pm
oh and the cam senson firts for me then id do the oil sensor
Old 29 Sep 2011, 01:04 pm
ok..I'll track down a Chrysler dealer around here for the MOPAR part..thanks..
Old 30 Sep 2011, 06:56 am
Call and see if they beat this price:
http://www.partswebsite.com/wyckoffm...n=3&type=parts
Old 02 Oct 2011, 04:55 pm
WolfmanG's Avatar
when my CSPS was going out, Eve was giving me so many different codes it was weird. So i went to the local dealer and bought one. I installed it and then ALL of codes disappeared
-Danny Wolfman G
Old 02 Oct 2011, 05:07 pm
If there is ANY doubt about your charging system or your battery, I would still suggest a visit to AutoZone or Advance Auto and have them do their tests. They are real time savers. I don't have any way to test individual cells nor do I have a load test unit to test the alternator, so whenever I get an issue related to electrical, if it's not apparently obvious I go get the free check from one of these guys!
Error codes: Luvour04ptgt Turbo Performance 3 25 Aug 2013 09:16 pm
Error Codes bucksfan1976 General Turbo Discussions 0 22 Feb 2011 01:03 pm
error codes??? Turboguy85 Turbo Performance 2 22 Sep 2010 05:15 pm
Error codes mr.troy Tech & Performance Forum 3 16 Jan 2007 04:26 pm
