Odd MIL light problem
Old 02 Oct 2011, 12:03 pm
Question Odd MIL light problem
OBED II reader indicates that the MIL light is on, but the light on the day isn't on. I the light shows when the key is in the run position, but turns off when the car is started. Any ideas?
Thank you everyone in advance
Edit*
The only code the computer is throwing is 1648 which I understand to be the code for the battery
Old 02 Oct 2011, 12:48 pm
Default Re: Odd MIL light problem
You don't have a problem, except with your code reader. The engine light is supposed to come on when you turn the ignition on and then go out when the engine starts.
You can clear the battery code by taking off the negative battery cable off for 5 minutes, but your code reader should have the option to clear the computer of that fault, if you know how to use it.
Old 02 Oct 2011, 12:56 pm
It stills registers when the codes have been cleared, it won't pass emissions with the MIL light registering
Old 02 Oct 2011, 01:23 pm
If it doesn't clear from taking the battery cable off and still won't clear by using the scanner/code reader, you have a problem with your computer.
Old 02 Oct 2011, 01:46 pm
OK thank you very much, guess I get to start playing with electronics next
Old 02 Oct 2011, 02:51 pm
Yes, once you reset via power down, hit the brakes a couple time to bleed off any excess system charge. After that, the code is reset until it reaches 50 indications of that code. Yes, 50. That means you have some tie between genning the code and clearing it to get it inspected. If it's never going away, there is some problem there.
Old 02 Oct 2011, 03:01 pm
The 1648 code isn't a failing code according to the sticky, so my next course is to change out the ecu. The from everything I've read I'll have to buy the ecu then take it to a dealer to be programed.
Brake light problem Cruiserbob General PT Cruiser Discussions 3 10 May 2011 12:27 pm
Brake light problem Shiniquiet General PT Cruiser Discussions 4 24 Sep 2010 07:05 pm
oil light problem HELP DPHC General Turbo Discussions 21 14 Aug 2010 10:46 am
Map light problem + new lights slayerdarkcross Interior Accessories Forum 5 11 Dec 2008 12:04 am
Dome Light Problem Johns Steel Blue General PT Cruiser Discussions 2 21 Aug 2007 07:51 am
