Good or bad?
Old 02 Oct 2011, 09:02 pm
Default Good or bad?
About a month ago my wife's 03 non turbo pt broke the timing belt while she was driving it down the road.We finally managed to get the new timming belt on and it put back together and it would run good at a high rmp but let off the acc. and it would lope and die.....now....ive got several question's....do the timming marks on the camshafts have to be aligned at 180 degrees across or can they be aligned but slightly higher than 180?...also...someone told me to do a compression test so i got one of my buddies to do it,he just called me and said that 2 cylinders were fluctuating between 70 and 80....the other 2 were at 120.....is this good or bad?
Old 02 Oct 2011, 10:40 pm
UptownSport's Avatar
Default Re: Good or bad?
Yikes.
God hope it's only the Timming that's off.
Simply use a straight edge to align timing marks.
First align the edge w/ center of gear bolts, then look at timing marks.
Old 03 Oct 2011, 04:46 am
Timing marks ....
Are these any good? Schweinhund Turbo Performance 8 15 Jan 2011 04:15 am
this any good? urimashe Tech & Performance Forum 10 04 Dec 2010 03:08 am
Good buy or not o8bluept General PT Cruiser Discussions 1 15 Mar 2010 05:18 pm
Good bye SFsGT03 General Turbo Discussions 3 28 Nov 2004 09:43 am
