02 PT center motor mount
Old 06 Oct 2011, 09:51 am
Default 02 PT Removing center motor mount "Help"
Im having a hard time understanding how to pull the center engine mount for my pt. Need to get the water pump out and cannot figure out how to remove the mount. Please tell me that somebody has done this.
Brandon
Old 06 Oct 2011, 01:18 pm
UptownSport's Avatar
Default Re: 02 PT center motor mount
Yikes. Detach exhaust, jack engine front WAY up.
Headgasket R&R
Old 15 Oct 2011, 02:58 pm
jdpersico's Avatar
put the right wheel off, and you'll see a circle plastic cap (it's about 2" diameter), take it off and you will see a T55 bolt, that's the one which is limiting you to lift the engine.
Then you should take the power wheel pump bracket. It has 3 15mm bolts (not sure about the 15 mm could be 13mm)
Then you're ready to lift your engine and remove your timing belt.
Old 15 Oct 2011, 06:50 pm
Also you'll need to disconnect the exhaust downpipe and the transmission mount also, so you can drop that side of the engine.
Old 15 Oct 2011, 11:06 pm
tryingbe's Avatar
I change the timing belt, all three mounts, waterpump, all without disconnecting the downpipe, a/c parts or touching the transmission mount. It was on a 03 GT PT.
85 GLH
Watch out for anchor engine mounts!!
Old 16 Oct 2011, 08:08 am
Good for you !!! but you dodn't want to put that much stress on the exhaust and the tranny mount, when you jack up and move the engine sideways for clearance. Anyways, you only need to remove the airbox and two 15mm bolts for the tranny mount, and four 13mm bolts for the downpipe
BTW, already did an 01 N/A and an 05 Turbo.... and a Neon, an Elantra, an Izuzu Amigo
Old 16 Oct 2011, 10:06 pm
jdpersico's Avatar
you only need to remove the 15 mm bolt that holds the exhaust manifold to the engine block. That allows you to lift the engine.
motor mount cllwyrc Tech & Performance Forum 13 04 Feb 2012 09:02 pm
Center Engine Mount on eBay compdr59 Tech & Performance Forum 0 01 Oct 2011 09:38 am
How to install the center motor mounts, or "Right engine mount" Leroy PT Cruiser Videos 0 21 Aug 2011 08:21 pm
Center Motor Mount Replacement jjackson23 Tech & Performance Forum 2 25 Jun 2011 12:20 pm
Motor Mount CityGirl70 Tech & Performance Forum 11 20 May 2011 10:51 pm
