AC pump high pressure switch
Old 06 Oct 2011, 04:58 pm
Default AC pump high pressure switch
Hello all! New member here. I've already got some useful info from this site...made changing the sparkplugs much easier! I have a question about the AC pump. Is the high pressure switch something that should come with a new pump or bought seperatly? I purchased the pump today and didn't notice it was missing till I got it back and unboxed. The parts place doesn't have a clue. This for a 2001 LE. Thanks for any info.
Joe
Old 06 Oct 2011, 05:18 pm
Default Re: AC pump high pressure switch
I can't answer your question directly, but there's more than one part that doesn't come with all that goes to it. The multi-function switch, which a few hundred if not thousand owners, had to buy a new one, and while replacing the burnt out switch, had to take the old flasher unit from the old switch and transfer it to the new switch.
As far as I can tell with looking at the pictures, a new accumulator doesn't come with the Low Pressure/Recycling switch either.
Old 07 Oct 2011, 07:46 am
Well I got it figured out. The switch does not come with new or re-man pumps...had to order it (non stock part at all of the local places) and should be picking it up this afternoon. Has anyone replaced the high pressure switch that could share any info?...just don't want to run into any more unexpected problems!
Thanks
Joe
Old 07 Oct 2011, 08:19 am
Google is your friend.
Trying to install High pressure ac switch on 2001 - FixYa
Oil Pressure Switch CruisinDad Tech & Performance Forum 4 28 Dec 2012 05:40 pm
A/C High Pressure cut-out Switch myanez Tech & Performance Forum 2 03 Oct 2011 09:59 pm
OIL PRESSURE SWITCH ??? badtxguard Tech & Performance Forum 2 25 Sep 2009 05:13 pm
High Side Pressure switch smithcruiser General PT Cruiser Discussions 4 08 Aug 2009 08:24 am
A/C Low pressure switch rhohmann General PT Cruiser Discussions 3 18 Jun 2009 11:50 am
