pls help, crank position sensor
Old 07 Oct 2011, 02:50 am
Default pls help, crank position sensor
hey guys and girls im new to the pt cruiser family, and im having problems already, the car cut off on me while driving today, after hooking up a scan tool, i threw codes for the camshaft sensor , and the crankshaft position sensor, i found the cam sensor but im having trouble locating the crank position sensor,please help, some sites say its on the back autozone says its on the front, any way i have a 2007 2.4 non turbo
Old 07 Oct 2011, 06:20 am
Default Re: pls help, crank position sensor
Yours is on the front, next to the starter BUT I've never seen a PT needing both the Cam and Crankshaft sensors at the same time.
Does the PT drive at all? What kind of mileage do you have? If it's high (anywhere nearing 100K), you might have broke the timing belt.
Cam and Crank position faults mid_life_crisis Tech & Performance Forum 9 14 Apr 2011 07:54 pm
Throttle position sensor Cruiser73 Tech & Performance Forum 4 23 Mar 2011 12:09 pm
Crank Sensor ejstith General PT Cruiser Discussions 3 11 Nov 2010 02:41 pm
Cam Shaft Position Sensor Johns Steel Blue Tech & Performance Forum 9 15 Apr 2008 07:38 pm
cam position sensor 4SPEED Tech & Performance Forum 1 25 Sep 2006 04:16 pm
