Car Still Jerking while increasing speed and stopped???
Old 07 Oct 2011, 07:49 am
Default Car Still Jerking while increasing speed and stopped???
Well guys my 08 PT(non turbo) is jerking at acceleration and while stopped still. This does not happen all the time while driving though, only an intermitted problem.
No Codes on the display(-d0ne-)
Wires, plugs, coil, MAP, PCV, Intake gaskets, #4 Fuel Injector have all been changed out.
Any idea's before I spend some $$$ at the mechanics.....
Old 11 Oct 2011, 07:52 pm
Default Re: Car Still Jerking while increasing speed and stopped???
Fuel filter or fuel pump? And yeah, if it's like my '01 N/A, those items are INSIDE the fuel tank. =total pain in the ***.
Cheers!,
-John
2001 Limited Edition
Old 18 Oct 2011, 04:18 pm
My 06 Tubo started doing the same thing last week and and then it worsened and the Malfunction light came on. I've just got it back from the shop and they had to replace the camshaft sensor.
Old 18 Oct 2011, 04:23 pm
EGlideRider,
Did you have the engine light come on? Did it show the P0340 fault code? It should have.
Old 19 Oct 2011, 07:36 am
Guess I will try to change the camshaft sensor and the IAC???
Hopefully this will clear it up.
Others in threads are having the same issue and have do this.
Old 21 Oct 2011, 01:35 pm
Originally Posted by CREWZIN View Post
EGlideRider,
Yes it did. Thanks for the reply.
04 PT, jerking when accelerating solluna975 Tech & Performance Forum 9 08 Feb 2014 11:45 pm
Increasing tire profile SteveWilson Wheels, Tires, Suspension 8 10 Jul 2009 01:50 am
Help on Increasing Performance 808 Tech & Performance Forum 9 11 Jan 2009 09:16 am
Increasing boost on a stock engine gpow General Turbo Discussions 3 06 Oct 2008 04:59 am
Funny Jerking Problem when stopped or braking, Help! CrisH Tech & Performance Forum 4 18 Apr 2008 10:07 pm
