2001 PT Cruiser not starting..my fault..any ideas on what to look for to fix it?
Old 07 Oct 2011, 05:48 pm
Default 2001 PT Cruiser not starting..my fault..any ideas on what to look for to fix it?
2001 PT Cruiser. I had installed a "SNAPSHOT" device from my insurance company in to the computer reader port..went well for 15 days..until my wife had the seat slid up and when I got in my knee "knocked" the entire device along with computer reader port off...big spark...now the car will not even attempt to start. All lights/horn/turn signals work. When I turn the key..nothing at all..looked at all fuses in dash..see nothing blown. Checked the fuse box under hood behind air filter..everything there seems fine..replaced starter siliniod..still nothing. Did I fry the computer possibly? or is there something else I can check?
Thank you for any suggestions.
Todd
Old 07 Oct 2011, 06:05 pm
Default Re: 2001 PT Cruiser not starting..my fault..any ideas on what to look for to fix it?
Did you re-attached the computer read-out port? Where there any wires pulled out or was everything looking good except that it wasn't attached to the underside of the dash?
Old 07 Oct 2011, 06:12 pm
the black plastic piece is off the read port..but I made sure that none of the wires are touching. I also tried disconnecting the battery for 30 minutes. Still no luck. Thinking maybe I am missing a blown fuse..going to go check again.
Old 07 Oct 2011, 06:54 pm
Not knowing you I have to ask, do you know there's two fuse boxes on the car. Interior and engine compartment. The two fuses in the engine compartment that could be connected to your problem are #3 (Ignition Run) and #17 (IOD). Make sure they are both good.
Old 07 Oct 2011, 07:09 pm
I did know there was 2 fuse boxes..but didn't really know which to check. Those initials on the fuse box are greek to me. It is too dark now but I will check those 2 in the morning. Thank you, I hope it is that. I will post in the AM.
Thanks,
Todd
Old 07 Oct 2011, 07:25 pm
Here's the diagram of the fuse box but it's 180 degrees from the way it is in the engine compartment.
You might check the starter relay also. You can swap it around with the horn relay (all relays are the same).
Old 08 Oct 2011, 11:52 am
Problem solved!!! car starts!!! thank you so much..it was fuse #17. Saved me towing/repair costs...thank you ...it is so nice when the car started..so happy...thank you for your help.
Todd
Old 08 Oct 2011, 03:03 pm
Your welcome Todd.
2001 cruiser not starting KingJames Tech & Performance Forum 2 21 Jun 2011 10:10 am
Help with starting 2001 Pt Cruiser Doc60 General PT Cruiser Discussions 10 10 Jun 2010 07:27 am
Pt Cruiser Not Starting teknoron Tech & Performance Forum 8 11 Sep 2008 02:04 pm
Any Ideas What's Wrong With My Cruiser? JoeyC33 General PT Cruiser Discussions 8 13 Aug 2008 07:33 am
2001 Starting question Circuitlaif Tech & Performance Forum 16 29 Mar 2004 11:33 am
