hard start when cold
Old 09 Oct 2011, 04:44 pm
Default hard start when cold
Oh wise ones, I have an 04 Touring with Turbo. When starting while cold
(usually first thing in the AM) it typically won't start until the second
attempt. It turns over but won't fire. There are no codes and almost always
starts fine for the the rest of the day. Plugs were replaced along with
throttle body cleaning approx 10,000 miles ago. Mileage is 85,000. ideas?
Old 09 Oct 2011, 05:09 pm
Default Re: hard start when cold
did you replace the plugs with stock and something diff.
Old 09 Oct 2011, 05:16 pm
It was done by a mechanic. I'd need to check invoice.
Old 09 Oct 2011, 05:42 pm
See if he changed the plug wires also. They do go bad.
Old 09 Oct 2011, 09:54 pm
Mopar wires, so I assume they're original. Any specific brand suggested?
Old 09 Oct 2011, 10:29 pm
Dino's Avatar
In my Toyota Camry I had that same issue and it was the cold start relay it's what makes the injectors fire when it's cold. It would always crank right up on the 2nd try and always on the first when warm out. It was an easy fix but I'm not sure how Chrysler does it.
Hard shifting and no start fixed fastone Tech & Performance Forum 10 23 Aug 2019 08:34 am
Upon Cold Start in Cold Weather, Loud Noise?? paulrosenthal Tech & Performance Forum 33 01 Oct 2014 09:55 am
hard to start steve smith Tech & Performance Forum 15 23 Dec 2010 08:36 pm
low vacuum, hard start after hd gasket replacement hondoland Tech & Performance Forum 6 31 Jul 2010 07:41 am
car didn't start in the cold, got jumped then was a bubbling sound and won't start Saqqara Tech & Performance Forum 1 15 Dec 2009 06:35 am
