Will a slipping, nonfunctioning transmission be covered under drivetrain warranty?
Old 09 Oct 2011, 06:30 pm
Default Will a slipping, nonfunctioning transmission be covered under drivetrain warranty?
The transmission on our '04 has been slipping, and now the car has no reverse, and will barely go forward. We've taken it in several months back for the same problem. The car has a 7/70 drivetrain warranty, currently the car has 66K miles and we've owned it slightly less than 7 years. The code is showing P 0700. Should this be covered under the warranty, or will we be hit with a costly repair bill tomorrow when the dealership opens (they're closed today)? I guess what I need to know is whether or not these transmission problems could be caused by "non-drivetrain" computer related issues, therefore not covered under warranty. What exactly causes the slipping issues with these trannys?
Old 09 Oct 2011, 06:36 pm
Default Re: Will a slipping, nonfunctioning transmission be covered under drivetrain warranty
It should be covered but you'll have to pay the $100 deductible. If it was in for the same reason before, be sure to take with you any paperwork that you have. Usually, the problems are totally related to the transaxle itself and not computer related.
The P0700 fault code is just a generic code saying that something wrong with the transaxle. Further diagnostics are needed to pinpoint the problem.
Old 09 Oct 2011, 07:29 pm
Thanks Crewzin, I'll be sure to take the paperwork tomorrow.
Old 09 Oct 2011, 09:40 pm
UptownSport's Avatar
Make sure they replace torque converter, flush lines and heat exchanger.
I'd prefer that dealership techs repair it instead of a 'reman'
Old 10 Oct 2011, 07:18 pm
Looks like they're going to have to operate. I was told it may be a day or two before they can tell me what the problem is, as it appears to be something internal. I was also told that it would be covered under the drivetrain warranty.
Old 10 Oct 2011, 07:33 pm
Old 10 Oct 2011, 11:10 pm
^^^ x2
Transmission Slipping-Told I need a new one for 4K..help! tolbin Tech & Performance Forum 8 04 Nov 2009 01:54 pm
Broken Seat... Is it Covered Under Warranty? Braves299 General PT Cruiser Discussions 4 08 Feb 2009 10:57 pm
AC hose covered under extended warranty? sawdust123 General PT Cruiser Discussions 13 29 Jul 2008 01:02 am
2005 Slipping Transmission already Espresso General PT Cruiser Discussions 7 16 May 2005 08:37 am
Tire sidewall bubble. Not covered by warranty? coolvirus Wheels, Tires, Suspension 15 10 Jan 2005 05:01 pm
