Cranks but don't start after TB replacement
Old 10 Oct 2011, 01:31 am
jdpersico's Avatar
Default Cranks but don't start after TB replacement
Hi, I'm Juan and I've been reading this forum since I bought my 2001 PT Cruiser (3 months ago) with 120K on it, and I found it really useful.
My Cruiser began to smoke at start up, but not during the drive. I think that the valve seals were the culprits. So I decided to replace them.
Since I was there I decided to replace the timing belt, water pump, tensioners, head gasket, torque struts, spark plugs, wires and also cleaned the injectors, made a valve job and a coolant flush.
I finished (finally) after one month with the car in the driveway. The problem came when I tried to start the car. It cranks, but don't start.
I've been reading here that could be a problem with the crankshaft o camshaft sensors, since I've removed the crankshaft.
The question is, if it's the mentioned above, how can I fix it? I tried disconnecting the negative from the battery, but still the same.
If not, any suggestions?
Thanks in advance
JD
Old 20 Oct 2011, 04:46 pm
jdpersico's Avatar
Default Re: Cranks but don't start after TB replacement
I checked for errors and I found a P0340 error. The camshaft position sensor. I checked all the wiring and it's Ok (actually I found that the resistance between the negative and the ground was 1.2Kohms, I jumped the black wire to the ground just to check if the failure came from a bad grounding, but no)
So now I'm going to buy a camshaft sensor to check if it starts.
BTW, does anybody knows how much vacuum is the correct?
Old 20 Oct 2011, 04:48 pm
cruserdad1976's Avatar
I am not nsure BUT i think there are 2 sensors that will plug into the same type of plug but they will not let the car start
Old 20 Oct 2011, 05:02 pm
jdpersico's Avatar
yes it's true, the camshaft sensor and the coil have the same connector, but I checked the color of the wires and they are OK (just in case I swapped them, but still won't start)
Old 20 Oct 2011, 10:51 pm
could it be 180 Out????
Old 21 Oct 2011, 12:13 am
jdpersico's Avatar
180 out means both crankshafts rotated 180 right? I put both with the arrows pointing up (at least I think so, I'll check it tomorrow)
I've been reading that sometimes the Chrysler's ECUs show the P340 Error when the Crankshaft position sensor is bad. Prior to buy the camshaft sensor I'll check it, maybe the wiring were broken during the engine lifting.
Also the P340 error could mean "camshaft sensor bad" or "camshaft and crankshaft sensors misaligned)
if the timing belt is OK (I hope so) How can I align both sensors?
Thanks for the help
Old 21 Oct 2011, 05:34 am
UptownSport's Avatar
Sounds like your cam timing's off.
Sensors go bad, but at this point with entire engine being dis-assembled
timing is most likely the problem
Old 21 Oct 2011, 05:01 pm
jdpersico's Avatar
Thumbs down Re: Cranks but don't start after TB replacement
Well guys, following your advice, I re-checked the timing, and surprise! (actually, coming from me, not surprise at all) , the exhaust camshaft is 180 out, so now I am officially stupid!!!
Tomorrow's will be a beautiful "re-timing day" in Ann Arbor
Thanks for your answers and I'll tell you if it works
Old 21 Oct 2011, 05:16 pm
jdpersico's Avatar
Another issue, Since I have the P0340 Error I checked the wiring to the sensor. I have ground in the middle pin (OK), 8.2v in one of the wires and 5v into the wire that goes to the pin 33 to the connector in the PCM. Is it OK?
Since the sensor works sending an electric pulse to the pcm, and this one compares this pulse with a 5v reference. Shouldn't be 0v between ground and the pin 33?
Old 27 Oct 2011, 03:13 pm
jdpersico's Avatar
Well, finally is working, but still smokes at startup, I checked the cylinder rings and they're OK, I replaced the valve seals and the head gasket.
Could be the PCV?
Tags
camshaft position sensor, crankshaft sensor, timing belt
Cranks but no start? C300392 Tech & Performance Forum 4 15 Apr 2016 07:58 am
Cranks but wont start master91599 Tech & Performance Forum 17 19 Dec 2011 02:58 pm
Help please, cranks but wont start!!! glockster5 General PT Cruiser Discussions 0 15 Apr 2011 10:33 pm
2001 PT cranks but won't start PT2001 General PT Cruiser Discussions 8 23 Oct 2010 10:41 am
engine cranks but wont start J_GEISLER Tech & Performance Forum 6 18 Oct 2009 08:21 pm
