Problems after engine swap!
Old 13 Oct 2011, 04:24 pm
Angry Problems after engine swap!
I bought a 2003 PT Cruiser with a bad engine. I did an engine swap using a 2003 engine with 88K miles. The engine won't start at all. There is no spark. I cleared the codes and once the key is turned on I get codes for the map sensor and tps. If I turn the engine over it adds four more codes. Any help would be appreciated.
Old 13 Oct 2011, 09:07 pm
UptownSport's Avatar
Default Re: Problems after engine swap!
These were the same sensors and harness as you originally had???
Harness didn't get pinched?
Old 14 Oct 2011, 08:33 am
Believe it or not, some of the connectors are identical and can reach more than one location - sure you have things connected properly? Did you mark harness connector locations before you removed the old engine?
Old 14 Oct 2011, 10:31 am
Astute analysis-
on Neon, cam and coil are same connector, and, yes, people have dun switched 'em!
Old 14 Oct 2011, 04:22 pm
Smile Re: Problems after engine swap!
I appreciate all of the input. I swapped the connectors from the coil and camshaft position sensor and it started right up. I bought this car with 140K on it and put an engine in it with 88K and a six month warranty. Total invested is less than $1,800.00.
Old 15 Oct 2011, 01:59 am
That's a sweet deal.
Old 15 Oct 2011, 12:12 pm
X 2!!!!
Old 17 Oct 2011, 12:57 pm
Thanks again!!! I had already bought the crankshaft position sensor and oil pressure sensor. It did need the oil pressure sensor. You saved me a lot of aggravation!
Old 17 Oct 2011, 02:52 pm
Originally Posted by mbsport165 View Post
II swapped the connectors from the coil and camshaft position sensor and it started right up.
Great! I thought that might be it...
ENGINE SWAP jonny Tech & Performance Forum 2 04 Apr 2011 08:49 pm
02 engine swap murphy Tech & Performance Forum 2 11 Dec 2010 12:44 pm
engine swap PTcruzer02 General Turbo Discussions 2 17 Jun 2010 10:01 pm
engine oil pan swap cruizinla Tech & Performance Forum 2 13 Oct 2009 07:32 am
02-03 Engine swap brit Tech & Performance Forum 0 13 Apr 2009 12:49 am
