How do you change rear brake pads on 2002 pt cruiser?
Old 14 Oct 2011, 11:09 am
Send a message via MSN to javolier
Question How do you change rear brake pads on 2002 pt cruiser?
thanks
Old 14 Oct 2011, 11:16 am
Default Re: How do you change rear brake pads on 2002 pt cruiser?
Is this a trick question? You change the rear disk pads the same way you do the front pads.
Are you sure they need changing. Rear pads generally last about 100,000 miles or more since 80% of the braking force is on the front pads.
Old 14 Oct 2011, 12:05 pm
I think that if only the rear squeak.
I will change the front too, although not very worn.
because I want to rectify the front discs.
Old 14 Oct 2011, 12:23 pm
Squeaking could come from a couple different places. Was anti-squeal liquid put on the back sides of the pads when they were first put on? Are the anti-rattle clips put on correctly? Is there brake dust built up in the brake area?
Old 14 Oct 2011, 12:31 pm
rear brakes are drums
Old 14 Oct 2011, 12:39 pm
rear brake pads/shoes
Old 14 Oct 2011, 12:45 pm
You said "rear brake pads" !!!
If the noise/squeak/squeal is from the rear and you have Drum brakes, all you have is built up brake dust. Almost all drums squeak when the brake dust builds up. Take the drum off and get rid of the dust.
Old 14 Oct 2011, 01:03 pm
for my :S
I will remove the tires and perform cleanup.
but if the front brake pads will be new.
thank you very much for your time as always
Best Regards
Old 14 Oct 2011, 03:04 pm
UptownSport's Avatar
In Neon's, friction will separate from metal shoes before they wear out.
It's not fun when this occurs!!!!!!!!!!!
In OLD 'rustbelt' PT's, might be best to replace pre-emptively.
Brake pads Geordie Wheels, Tires, Suspension 4 02 Apr 2010 03:13 pm
How do you change a battery in a 2002 Pt Cruiser Turbo? ptshmoozer Tech & Performance Forum 5 31 Jan 2009 03:24 pm
Brake Pads Gumbias General PT Cruiser Discussions 3 12 Jun 2008 10:32 am
Brake pads gonzomania General PT Cruiser Discussions 9 02 Dec 2006 05:51 pm
New Brake Pads Gunner General Turbo Discussions 12 02 Apr 2004 03:26 pm
