tire size question??
Old 14 Oct 2011, 01:56 pm
mdskinner731's Avatar
Default tire size question??
ok i just had a set of 205/60/16 given to me!! less than 75 miles on them!!! will they fit on the front end of my pt with out hitting??
i have been running 205-55-16 before with no problems
Old 14 Oct 2011, 02:19 pm
Default Re: tire size question??
If you have the original springs on your PT, your should have a problem with those new tires. There's enough room in the wheel well so they won't harm/touch anything. You just increasing the aspect ratio a small amount. It probably will throw the speedometer off a small amount also.
Old 14 Oct 2011, 02:55 pm
DuRoc's Avatar
I'm going to the same size for a little more sidewall. Should be no problem is what I have been told. Speedo will read a tad slow but not much.
07' 5.7 QCSB Ram, 06' 5.7 300C, 04' Cruiser LE Turbo
Old 14 Oct 2011, 03:54 pm
i can deal with slow... reminds me of the operator... lol jk jk but for free ill put em on the front!! if the rub ill switch em to the rears!!
tire size question 4SPEED Turbo Wheels/Suspension/Handling 3 12 Dec 2008 01:22 pm
Newbie with Wheel/Tire Size Question digitalpinscruiser Wheels, Tires, Suspension 6 27 Jun 2008 06:04 am
Age old question (again) max tire size stock wheel BobM_CT Wheels, Tires, Suspension 8 21 Nov 2003 02:53 am
Tire Size scvcruzr Exterior & Interior Styling 4 02 Jul 2003 12:58 am
tire size tom Tech & Performance Forum 3 16 Nov 2002 01:42 pm
