Ideling and running rough?
Old 15 Oct 2011, 12:04 pm
War_Eagle's Avatar
Default Ideling and running rough?
I have an 06 GT with 53k. I recently moved from Florida to Wisconsin. A couple of days ago it started idling rough and hesitating on takeoff. I always run 91 or better octane fuel and did spark plugs and wires 8k ago. Any ideas? Fuel injectors, vac lines, it's not throwing any codes yet. What does a new fuel injector job go for? Any help is appreciated........
2005 Silver GT, auto, black leather, HID Headlights, ST Front sway bar, 215 45/17 tires, dark tinted front windows, stock running gear, sickspeed black pearl shift knob.
Old 17 Oct 2011, 02:48 pm
Default Re: Ideling and running rough?
Hope plugs were gapped at about 0.040.
THrow some Lucas fuel injection cleaner in gas - can't hurt.
Here's another idea:
Finally Got rid of that annoying hesitation
Old 18 Oct 2011, 07:59 pm
War_Eagle's Avatar
Replaced the cam sensor and that seems to have taken care of it, I hope.
Old 18 Oct 2011, 08:24 pm
You replaced the Camshaft sensor and it didn't throw a code for it?
Old 03 Nov 2011, 10:59 pm
My 05' pt gt only idles rough when i shift into drive. If i shift to neutral or park it idles alot smoother.
any ideas?..apparently i've had the cam sensor already replaced, but i swear it ran rougher after that
Old 04 Nov 2011, 08:48 am
You need a Mopar cam sensor - you can get it online from a Chrysler dealer website like Wyckoff or MoparPartsAmerica, etc. There are replacement sensors that just don't work as well - lots of posts of people who tried them, then got a Mopar part and fixed the problem.
Have you replaced pugs & wires recently? Plugs gapped at 0.040 (or even a little less)?
Car is stalling/RPM's Go up and down/running rough and stuttering/NO ERROR CODES? darkpt06 Tech & Performance Forum 3 28 Sep 2011 06:55 pm
Running rough at idle only brimmstone General Turbo Discussions 7 30 Nov 2010 04:05 pm
Rough running '06 GT CruzinGT General Turbo Discussions 14 21 Nov 2010 08:45 pm
Running Rough...New timing belt, water pum and spark plugs lanies_ptcruiser02 Tech & Performance Forum 15 05 Sep 2008 09:59 pm
01 PT Running Rough lucky594 Tech & Performance Forum 5 17 Aug 2007 11:22 am
