timing belt installation???
Old 17 Oct 2011, 07:12 am
mdskinner731's Avatar
Default timing belt installation???
ok header is installed!!! new head is installed!!! new water pump too!! and a few various other mods have been completed!! now its time for the timing belt to be installed!! i have installed it 3 or 4 times to find out that the cam gears have rotated thus not having the timing marks lined up properly?? any pionters or tricks to doing tis job??
Old 17 Oct 2011, 09:31 am
cruserdad1976's Avatar
Default Re: timing belt installation???
I think there is a special tool that will hold the 2 cams in the correct position im sure some one will chimne in I think there were even pic's
Old 17 Oct 2011, 10:09 am
some how?? either way... it aint easy... and i thought the timing belt on my mustang was hard to do... lol ill get er some how... lol but HELP.... lol
Old 17 Oct 2011, 11:07 am
UptownSport's Avatar
Best is to time w/ rocker cover off-
There's two holes- Install rods, extensions, etc. They need to be parallel.
Use a straight edge across cam bolt center (ensure you torque these bolts!!)
(you can see one hole in upper right corner of this pic)
The holes are in area with arrows on below picture
Old 17 Oct 2011, 12:12 pm
how do i keep the cam gears from rotating while installation of timing belt?? the cam gears are torqued to spec. but evry time i try to install the belt the cam gears rotate.. thats my biggest problem.
Old 17 Oct 2011, 01:21 pm
rcktpwrd's Avatar
There is a special tool that holds the gear from turning, I made my own from a piece of flat steel stock and a couple bolts... A web search have me pics to copy.
Joel
www.rcktpwrd.com
Old 17 Oct 2011, 03:14 pm
Use an 8mm or 5/16" socket with short extension on time belt screws to stop gear turning- works Great!!!
See below for approx bolt location:
Old 17 Oct 2011, 03:29 pm
We used this tool last Saturday and it works GREAT !!!!
Pulley Spinning Tool
Old 17 Oct 2011, 04:45 pm
Use an 18mm wrench. Don't have too much trouble here.
You can move belt to extreme exterior and slip one tooth
back / fro on pulleys
Old 17 Oct 2011, 09:12 pm
tryingbe's Avatar
There is this tool in the Volvo world, I'm sure you can make your own.
85 GLH
Watch out for anchor engine mounts!!
timing belt Thomas1 Tech & Performance Forum 20 21 Jul 2012 09:06 am
Timing belt installation check from the top? worcestersauced Tech & Performance Forum 3 01 May 2011 09:33 pm
Belt change help - Not timing belt skfloyd Tech & Performance Forum 2 23 Apr 2010 11:23 am
