Updated Oil Cooler and Lines... Anyone heard of this?
  • 1 Post By Busted_PT
Old 17 Oct 2011, 06:53 pm
Default Updated Oil Cooler and Lines... Anyone heard of this?
I had my 2003 PT GT oil changed at a different place than normal and it leaked all over my garage (compared to the chain place I normally go to who everyone says not to). Took it back and they said it was oil pan and I replaced it.
Now it's leaking a lot... like probably 1/4 a cup in two days on the garage floor.
Took it back today and they said oil pan is fine and that there's a updated oil cooler with lines that Chrysler has as an update to leaking flaws... since not safety it's not a recall but it needs this update as it's known to leak ($450). I told them "no way" so they said they'd put on a Mopar filter and see how it goes.
I can't find anything even close to this searching google. Is this shop telling the truth... or am I being fed a BS story out here in Frisco, Texas.
Does anyone know if this is true?
Jeff
Welcome to Scepteronline.com!
Old 17 Oct 2011, 07:22 pm
DuRoc's Avatar
Default Re: Updated Oil Cooler and Lines... Anyone heard of this?
Jeff
Are you sure it wasn't leaking from the oil filter, like maybe they spun on a new filter over the old filters o-ring? Rookie mistake but I have seen shops do this before, happened to me before.
07' 5.7 QCSB Ram, 06' 5.7 300C, 04' Cruiser LE Turbo
Old 18 Oct 2011, 05:43 am
Has happened to me, too... but that will lose a LOT of oil
The most usual cause of oil leaks is gorillas changing the oil and either stripping or cross-threading the oil plug - there is no issue with oil lines/cooler.
If you don't know where it's leaking from, there is a dye can be put in the oil that shows up under U-V light - but don't take you car back to the place that screwed it up!!!
Old 18 Oct 2011, 03:05 pm
Kawizx9r's Avatar
One; don't take it to the shop. You can do an oil change yourself and it's easy as pie. Plus you can rest assured knowing that your oil was changed and your oil filter...you'll be surprised how shady a couple of places are where they won't change your oil filter.
Two; clean your engine bay both up top and underneath, more importantly underneath. I'm talking brake cleaner/wiping down/spraying/etc. A clean engine bay isn't just for looks, if it's clean and you suddenly develop a leak you'll know exactly where it's coming from.
Three; jack car up, let it run/warm up/idle and shut it off. Try to find out where it's leaking from.
FYI Only use synthetic oil, I prefer Mobile 1 full synthetic. I don't know how long you've owned your PT GT or how familiar you are with turbo cars but if you drive it hard, let it cool down. Using synthetic oil and letting things cool down prior to shutting the car off prevents clogging of your oil lines. Synthetic oil burns at a much slower rate, hence why you want to use it. Also, when you first start up the car unless you let it warm up a bit, drive it like an old lady and don't start boosting anytime soon. You'll easily kill a 'dry' turbo that way.
Kawi is a friggin genius!
Old 18 Oct 2011, 09:07 pm
mdfrodolives's Avatar
Well ... if I were you, I'd take the car into the previous shop you used to have change your oil. Ask them what's up. Even though "everybody says not to go to them", you never had this problem in the past--when you were going to them. Right?
Updated oil cooler and lines? That's poppycock! Your new shop, either cross-threaded your drain plug; overtightened your filter (causing its seal to rupture); left some of your old oil filter seal on the car and screwed the new filter on top of it; or they may have even loosened some of your oil pan bolts to make it leak on purpose--just so they could sell you an "updated cooler and new lines.
Go back to your original oil-change mechanic.
Tim
Old 19 Oct 2011, 06:29 pm
VNT's Avatar
VNT VNT is offline
I assume you have a turbo
The oil cooler has two coolant lines to it. A feed and a return, both have preformed steel sections and rubber sections. the rubber sections slide over two nipples on the cooler, see the picture
In 2005 they increased the OD diameter on the nipple on the cooler from like 9/16 to 5/8, so you cant buy the old hose and superceded to a kit with new cooler. I grabbed some of the old hose which are now NS1, so anyone with a 03 and 04 is screwed when they need to replace the coolant lines for the oil cooler. I would assume people are now about due since rubber hoses have about a 10 year life span
VNT
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
05 PT GT Silver 5 Spd Conv
17 Challenger SRT A8 GoMango
18 JL Wrangler Sahara Punkn
Old 27 Sep 2013, 12:43 am
OH so freakin true!!!!!!!!! the cost of a new cooler is 133 and I have a 05 turbo. If I had the GT there would be no problem, info found out from dealer. They should have just made one size for all turbos. The complete line assemblies not just the rubber hoses are 156 as well. They are only dealer stock items as they are molded and have different end sizes.
Old 27 Sep 2013, 07:36 am
These lines are coolant only. No oil leak associated with these lines. Not sure if there would be any difference in the gt. Nothing else is. And this thread is 3 years old. Many of the op's have left.
mole likes this.
Old 11 Feb 2014, 12:02 pm
What do you Mean - "If I had the GT there would be no problem" - the "lite" and GT are identical except for computer programming - the Lite has lower boost.
has anybody heard of this or done it gonzomania Tech & Performance Forum 4 20 Mar 2007 11:47 am
anyone heard of KYB??? turbomangt Turbo Wheels/Suspension/Handling 6 02 Dec 2005 12:29 am
Heard of VSI?? turbomangt Turbo Wheels/Suspension/Handling 1 23 Apr 2005 05:08 pm
Thanks, they heard me turbomangt General PT Cruiser Discussions 9 15 Oct 2003 01:44 am
Check your AutoStick transmission cooler lines! ElectricBlueGT General Turbo Discussions 4 03 Oct 2003 09:53 pm
