Timing Belt/Water Pump Help
Old 20 Oct 2011, 10:03 am
Question Timing Belt/Water Pump Help
Hey everyone. I'm back. We are now having to replace the timing belt and replace the water pump. Would you be so kind as to send us instructions with photos like you have in the past??? So far, my husband and I have been able to fix our car on our own this past year, which helps us so much! I have MS and my meds are so expensive, so every little bit helps! We have a 2003 non-turbo Cruiser.
Thanks again for your help!! I don't know what I'd do without this forum!!
Old 20 Oct 2011, 10:41 am
cruserdad1976's Avatar
Default Re: Timing Belt/Water Pump Help
MamaCruiser:
I respect your ability to fix you can and its a lot of fun to get under the hood and turn wrenches There is a sticky in the tec section on How to a timing belt----HOWEVER I will also tell you that
1. The timing belt/Water Pump /tensioner--IS by far the HARDEST thing you will ever work on
It is a LONG job and it is a Pain there is no room
everything is in the way
I guess you do not have to have a shop but you will be taking a lot of parts and nuts and bolts off and I do mean A LOT
If I were you id read some of the threads adn maybe pm some of the guys this is a MAJOR Undertaking
I wish you all the luck in the world and send many good wishes your way
I actually cheated and took mine and had it done with the understanding that there was a SOLID warenty if the timing was as much as 1 tooth off
Good Luck
Old 20 Oct 2011, 11:05 am
UptownSport's Avatar
Yep, here's the tech How-to section:
HOW TO's
Old 20 Oct 2011, 11:18 am
with Cruserdad 100%. About the hardest job there is to do on a Cruiser. Even mechanics have gotten it wrong and the car owner comes here for advise and 99 out of 100 are told that the timing is off and the job has to be done over.
Old 20 Oct 2011, 12:04 pm
Crewzin I did kind of proof read that and it actually readable
Old 20 Oct 2011, 12:15 pm
Where to buy Timing belt/tensioner/water pump KalSaint Tech & Performance Forum 4 24 Nov 2011 09:02 am
Timing Belt/Water Pump mybubbles65 General PT Cruiser Discussions 3 04 Oct 2011 04:47 pm
water pump and timing belt bryanschacht Tech & Performance Forum 3 15 Apr 2011 05:32 pm
TIMING BELT AND WATER PUMP CHANGE?? mjb457 Tech & Performance Forum 20 03 Apr 2011 10:38 pm
Changing timing belt and water pump.... missingwhatsnear Tech & Performance Forum 14 13 Dec 2010 04:22 pm
