Bad Fuel Economy? You might check your Exhaust Manifold (pic)
Old 21 Oct 2011, 08:03 pm
UptownSport's Avatar
Default Bad Fuel Economy? You might check your Exhaust Manifold (pic)
Same as Neon, exhaust manifold cracks, O2 sensor sniffs extra
oxygen(from crack), believes engine's running lean and tells PCM
to puke in fuel.
(Although it looks like it, horizontal line isn't a crack, casting part line)
Other side was cracked, too; there was a fresh layer of
soot on combustion chamber / pistons.
Rockauto.com has the manifold,
DORMAN Part # 674662 Hardware: 4 Studs, 4 Nuts; Gaskets: 1 Manifold, 1 Flange $75.79
Ma Mopar (Dealer)
4884460AA $150.00
Exhaust system - Exhaust manifold
Exhaust manifold, pt cruiser, w/o turbo 2001 - 2010
Old 21 Oct 2011, 08:06 pm
Default Re: Bad Fuel Economy? You might check your Exhaust Manifold (pic)
whoa, that's ugly. I'm gonna run my pen cam around mine and see if I pick up any cracks.
Old 21 Oct 2011, 08:18 pm
Checked mine, the best I could, no cracks.
Old 21 Oct 2011, 11:54 pm
dsmturbo's Avatar
Send a message via MSN to dsmturbo Send a message via Skype™ to dsmturbo
Yes I remember the Talon 2L turbos were notorious for this as well.
Old 22 Oct 2011, 11:15 am
Unfortunately, you'd need to remove shielding to see cracks,
unless they're awesomely large.
Here, again is 2.0 version:
You can weld it, nickel rod and heat / cool with oxy /acetylene torch:
(Note relieving strike marks)
1st pictured manifold was so severe, I wouldn't try welding, perhaps brazing.
Old 22 Oct 2011, 12:30 pm
dsmturbo's Avatar
Ah man, gonna need a hoist. I guess I should get mine checked
Old 22 Oct 2011, 02:19 pm
I think, if you look @ Crewzins pic, you can remove shield on car.
See one of crewzins looks snapped, but I've had really good luck with them. A little lube underneath on long bolt threads helps if it starts to move.
Old 22 Oct 2011, 02:25 pm
Yea, it snapped while changing the upstream sensor but there are 4 bolts that hold the shield on so I figured 3 was good nuff.
Old 22 Oct 2011, 06:36 pm
mityqwik's Avatar
Thumbs up Re: Bad Fuel Economy? You might check your Exhaust Manifold (pic)
i will be checking mine tomorrow,i hope all is well
It takes 8,460 bolts to assemble an automobile,
and one nut to scatter it all over the road
Old 24 Oct 2011, 07:52 am
mdskinner731's Avatar
http://http://www.ebay.com/itm/New-E...item41572e40d7
i purchased this item and it bolted right up alls good! my manifold pretty much broke in half wen i took it off of my car... but on the flip side... the O2 sensor came right out with no problem at all!!!
Fuel Economy Issues JaxCruzzer General PT Cruiser Discussions 11 02 Mar 2011 03:18 pm
All this ... and the Fuel Economy improves? PlatinumTurbo Stage Turbo Kits 14 21 Jan 2007 02:10 am
STAGE 1 may mean better fuel economy! Gary04GT Stage Turbo Kits 10 20 Jul 2004 01:30 am
Turbo Fuel Economy PB General Turbo Discussions 23 11 Dec 2003 03:26 pm
