Old 22 Oct 2011, 06:43 am
Thumbs down 2302
I have an 04 with turbo and have had my car in a shop all week and they cant figure out how to fix it
Old 22 Oct 2011, 06:45 am
Default Re: 2302
Any advice would be great
Old 22 Oct 2011, 06:57 am
Default Re: 2302
P2302 ignition coil #1 secondary circuit, insufficient ionization
Set condition: if the PCM detects that the secondary ignition burn time is incorrect or not present, and error is detected.
Possible causes:
spark plug
ignition wire
ignition coil
Everyplace I looked it had the same causes for that code. A good shop will have a diagnostic tool that they can plug in as drive and give the results of tests that run and things that it monitors while you drive. Try and find a shop/dealer that has that diagnostic tool.
Old 22 Oct 2011, 07:45 am
Default Re: 2302
Make sure your coil and sensors are OEM MOPAR
Old 22 Oct 2011, 01:14 pm
Default Re: 2302
Your computer makes a measurement across the coil and that measurement is supposed to fall in a small window. I don't remember the measurement nor the window of what it's supposed to be, but I do know that non-OEM coils tend to fall outside the parameters set on your ECM.
Old 13 Apr 2012, 02:21 am
Waker's Avatar
Default Re: 2302
I purchased an American-made coil from Napa and it's working very well thus far!
2nd owner (acquired in 2006 w/ 3,500 miles on it) of a Black 2005 PT Cruiser Convertible, Touring Edition 2.4L Baby-Turbo, Automatic.
It was the Missus dream car that quickly killed the dream! How? Within 5 years and 40,000 miles replaced: Turbo (warranty), A/C system (warranty), 3 engine mounts (warranty), Trans. Solenoid Pack (warranty), Key Chip Skim (warranty), Spark Plugs & Wires the dealership wanted $241 to put in when they were owed to us because of the carbon-arcing problem w/original factory plugs (Champion Plugs, Really? On something other than a lawnmower?!? Now running Bosch wires and new Bosch Iridium +4 plugs).
Now it's paid off, the warranty has expired and its care is all on me! Please help if/when you can and I'll do the same!
P 2302 Fault Code unable to find Turbo Red General PT Cruiser Discussions 2 08 Feb 2004 12:37 am
