05 PT - no air during idle, rough idling.
Old 22 Oct 2011, 08:59 am
Default 05 PT - no air during idle, rough idling.
Hi everyone!
My mother-in-law is having some issues with her 05 PT cruiser (again!).
It has about 130 000km, and is non-turbo.
The car idles fairly roughly if you are trying to blow hot air or air conditioning.
The air blows just fine at either temperature while the car is driving.
Then when you come to a red light, no air.
In the summer, it wasnt such an issue.... but in our lovely Canadian climate, this car will never warm up enough to drive soon.
Anyone got any ideas?
I've seen you guys come up with awesome ideas on here, dont stop on my account!
Thanks!
Old 22 Oct 2011, 09:40 am
Default Re: 05 PT - no air during idle, rough idling.
For most cars, I'd recommend checking the idle air control valve and cleaning the throttle body.
But I just recently discovered, that for a PT, those symptoms are often a result of a burned out radiator fan. I just had that exact problem -- rough idle w/AC on and no air at idle and the radiator fan was the culprit.
Old 22 Oct 2011, 10:02 am
So, you mean the radiator fan motor?
Old 22 Oct 2011, 02:36 pm
Yes, the radiator fan motor. A very weak link in the cooling system. Let everything cool down. Start the car and put the A/C ON, now check to see if the fan is running. The fan should be on ANY time the compressor is ON which means the A/C or defrost mode which also turns on the compressor.
Old 31 Oct 2011, 10:44 am
turns out the radiator fan motor was toast, and the radiator has a slow leak...
This PT really is a lemon..
The list of problems never seems to end.
2001 PT surging and rough when idling Sue Tech & Performance Forum 8 31 May 2016 11:09 pm
Rough Idle-Replacing the IAC Idle Air Controller engineerrock Tech & Performance Forum 9 07 Jun 2014 07:24 pm
PCV Valve? Idling Rough/High MattTee Tech & Performance Forum 4 17 Jan 2010 06:25 pm
Rough Idle, Rough @60, check engine light NEW Dystroy Tech & Performance Forum 8 12 Jan 2009 09:07 pm
Rough idling, backfiring, hesistation DJR General Turbo Discussions 19 08 Feb 2006 10:05 pm
