Timing belt
Old 25 Oct 2011, 09:14 am
Default Timing belt
Hello all,
So my 2002 PT limited decided it was time to break a timing belt. I've been reading alot on here, and have the Haynes manual. I was wondering if I would be better off removing the engine to replace the timing belt or just do it with the engine in place?
Old 25 Oct 2011, 09:24 am
Default Re: Timing belt
Originally Posted by fourwheeler04073 View Post
Hello all,
Are you crazy? keep the engine in place!!!! just disconnect the engine mount, tranny mount, exhaust downpipe and get two jacks and lower the driver side of the engine and raise the passenger side, then you'll get enough room to remove that big cast iron center mount bracket.
Old 25 Oct 2011, 09:51 am
That's what I thought but 1 repair shop mentioned engine removal. I'll be starting on it tomorrow afternoon. About how long do you figure it should take? couple days?
Old 25 Oct 2011, 10:20 am
What's your experience in doing something like this? Is the Haynes manual your guide?
Look in the Tech and Performance section for the "HOW TO" thread and print out any of the helpful threads that say anything about the timing belt. You might think twice before taking on the job.
Old 25 Oct 2011, 04:40 pm
Just curious, how many miles do you have on your PT?
Old 25 Oct 2011, 09:33 pm
XDC2 - sorry man - you totally downplay how tough this is. If I had the equipment, I would totally pull the motor. But then again - if I had the equipment I probably would have a lot more experience and probably wouldn't.
It took my dad (seasoned driveway mechanic works every weekend on cars since the 60's - with air tools and access to a lot of stuff most people don't) and myself (a self-described ghetto mechanic with a lot of tools that specializes in doing major repairs in parking lots) - 2.5 days to complete. That is a Saturday, a Sunday, and taking off work Monday to button back up. Every Single Thing took longer and was harder than expected didn't line back up, got stuck, etc. Might just be my luck.
My thread:
Pre-emptive timing belt change completed!
(note this is the 2004 I own that I did pre-emptively - my wifes 2001 actually had a couple valves and a valve guide break when hers went. Yes I saw them myself. I understand I'm one of a few that actually had this happen.)
Old 25 Oct 2011, 09:58 pm
My thread:
I'm not saying is an easy job, but if somebody is asking if you need to remove the engine, I'm going to give him the right answer: You don't need to
Already done a full timing belt change on my wife's and helped a member doing a second one (compdr59), and is not the end of the world to do it.
Yes, if you never did it before you'll need a full weekend...but if you already done a few is not that bad....I already did it in all my family's cars: Isuzu Amigo, Hundai Elantra, Dodge Neon, PT Cruiser, Ford E150 (timing gears), so to me is not hard.
BTW, I'm not a mechanic but I worked on many different jobs in the past 20 years, so I learned to do everything, like carpentry, electrical, machining, rigging, plumbing, printing, etc,etc
Old 25 Oct 2011, 10:58 pm
compdr59's Avatar
Engine removal is not the answer.....
Make sure you're not in a rush. The spaces are tight and the manual doesn't show you where is the best access position. I couldn't get a socket on the alternator belt tension bolt, I had to use a box wrench. You will need some special tools for the front pulley and to hold the camshafts. My socket set didn't have 18mm sockets. You will need a Torx 55. The rented pullers don't remove the front pulley all the way, you will need to improvise to get the last 1/2". Plan on at least two full days and you will need an additional set of hands to put the belt on. My car was garaged since new so I didn't run into any frozen bolts. I hope I never have to do it again on a PT, but I will need to change one on my RX330 one day.
Let us know if you have any additional questions.
Original Owner 135k
Old 26 Oct 2011, 07:35 am
mdskinner731's Avatar
for me its been an on going battle with the timing belt job... however.. since every thing is off and accessable ive decided to take my time. (out comes the beer and every thing slows down) if i were you i would replace every thing before it goes back on the engine!! one down fall for me is... i never changed the crank shaft seal highly suggested to change the water pump... and the tensioner... and anything else you can while its apart!!! just my $0.02 tho
Old 26 Oct 2011, 08:42 am
tryingbe's Avatar
Waterpump and tension is a given. They might be ok now, but they will not last another 100k!
I'd change the front main seal, cam seals, center engine mount. All these require the timing belt to be off. You'll need a special tool to pull the crank sprocket off.
Also check the valve cover gasket if it is leaking.
85 GLH
Watch out for anchor engine mounts!!
timing belt cruiser4475 Tech & Performance Forum 0 13 Jul 2010 06:24 pm
Belt change help - Not timing belt skfloyd Tech & Performance Forum 2 23 Apr 2010 11:23 am
timing belt greg55 Tech & Performance Forum 1 08 Mar 2010 09:19 pm
