Strange Electrics
Old 27 Oct 2011, 06:24 am
Default Strange Electrics
New to site hope Im posting right. Have an 06 gt conv turbo on occasion the instrument cluster goes wild, gauges spin, all the lights flash and sometimes the engine starts sputtering. This has been going on for many miles. No dealer could find the problem. Now I have it at the shop and it happened to them twice. Thier still not positive but say 90% it needs a new PCM. Any thoughts?
mbaker115 likes this.
Old 27 Oct 2011, 06:39 am
Default Re: Strange Electrics
PT's go nutty when the battery is not fully charged. Have the charging system checked and also take the negative battery cable off for about 10 minutes and depress the brake peddle for a couple seconds. That gets rid of all residual charge. Put the cable back on and see if there's any change with your problem. Let us know if that helps.
Old 27 Oct 2011, 07:05 am
Thanks, I do have a new battery in it I'll try what you said and let you know. Dealer wants to charge 600 for PCM installed sounds high??
Old 27 Oct 2011, 07:19 am
There is a federal law regarding emissions - I am not sure of upper mileage limit, but if you have less than 50,000 miles, pretty sure they have to replace PCM for free.
Old 27 Oct 2011, 07:23 am
I think that limit is 80K
Old 27 Oct 2011, 08:39 am
VNT's Avatar
VNT VNT is offline
I dont have the part # handy but in the steering column their is switch. It is about 40$. It connects to the key tumbler and has an electrical connector.
It requires a tourx bit #10 on a 1//4 drive rachet to remove. takes about 1/2 hour to replace.
Do a search on cluster going crazy. I replaced the one in my wifes 2006 GT and the problem hasnt come back.
If you opt to go this route, please buy the Mopar one from the dealer, the aftermarket electronic stuff is junk!
Ignition switch
VNT
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
05 PT GT Silver 5 Spd Conv
17 Challenger SRT A8 GoMango
18 JL Wrangler Sahara Punkn
Old 27 Oct 2011, 05:19 pm
Thanks for all the help,85k so they wont cover. It did it again with new battery, if it was the tumbler would it stall the engine?
Old 27 Oct 2011, 05:22 pm
If you read his post link you'll see Both rudedude and txcruiser states that it included stalling.
Old 27 Oct 2011, 05:36 pm
Found it, I'll replace this weekend
Old 31 Oct 2011, 05:41 am
Well well the stealer, Palm Crysler in Punta Gorda, says PCM only $640. If that doesn't work new gauge cluster for $450+++. Switch??? no way. Thanks guys, replaced switch electrical connector, $60 ,drove it all weekend, no problems. Also instead of removing the tilt arm bend it very slowly to gain a little clearance then bend back. Be carefull not to break the plastic spacer. I hate dealership service depts.
Electrics/ switch problem - computer thinks a door is open Jargo Tech & Performance Forum 14 21 Oct 2014 04:24 pm
Strange headlights SCBluePT Exterior Accessories Forum 16 20 Jul 2011 09:44 pm
all the electrics went crazy!! flyeguy PT Cruiser Convertible Forum 4 29 May 2010 08:18 pm
Does not start (no ignition / electrics OK) - HELP!! aljimtom Tech & Performance Forum 6 30 Dec 2009 11:13 am
Strange smell... Rooney Interior Accessories Forum 1 27 May 2008 01:13 pm
