Stalls after start and loss of power
Old 29 Oct 2011, 12:49 pm
Default Stalls after start and loss of power
This is crazy car 03 turbo with 98k(turbo was replaced at 70k) was running fine till my mechanic put the front on the lift(didnt raise the whole car) to fix ball joint. Later when i went to start it didnt want to start or stalls after start. Frist start in the morning is great fires fine till the 3rd or 4th tims then gives me problems and im also lossing power mosly on hills. We rplaced the coil last week and the plugs and wires are all new as well. Cam sensor was replaced a few months ago. I dont remeber what the codes where but it was 02 sensor and 4th cyl missfire. Anyone?
Old 29 Oct 2011, 03:41 pm
Default Re: Stalls after start and loss of power
I have the codes, 38, 304 and 1188
Old 29 Oct 2011, 03:55 pm
So you know the codes 38 (02 sensor) and 394 (4th cylinder). The other is P1188:
Non-boost Mode: PCM detects a significant difference between TIP Sensor signal and BARO Pressure signal.
Boost Mode: The TIP Sensor is unable to read correct boost level.
Possible causes include:
Hoses and Tubing
Vacuum Supply to Surge Solenoid
Solenoid Test #1
Solenoid Test #2
Solenoid Test #3
Solenoid Test #4
Turbocharger
Wastegate Actuator
Sounds like the mechanic might have loosened something, maybe a hose or vacuum line while on that lift. A loose or broken vacuum line will bring more air into the engine and maybe set off the 02 sensor. On the No#4 misfire, change the #4 plug by putting it on No#2 cylinder and see if the code changes. Clear the code by taking off the negative battery cable for a few minutes.
P0340 & P1391 code // cold start & occassionally stalls apalomo01 Tech & Performance Forum 13 28 Jul 2012 08:00 pm
Power and MPG Loss Smurfy Tech & Performance Forum 10 28 Jun 2011 08:31 am
'03 Cruiser Stalls, Won't Start bjagd02 General PT Cruiser Discussions 5 22 Feb 2011 06:33 pm
2001 PT - Starts, runs, stalls...won't start silver7 Tech & Performance Forum 12 20 Sep 2010 03:11 pm
Loss of power slcpunk Tech & Performance Forum 9 15 Apr 2009 12:51 am
