oil leaks
Old 29 Oct 2011, 01:54 pm
Default oil leaks
i noticed oil on one of the bolts next to my oil cap could this be from oil cap or head gasket and does anyone have a oil leak problem with thier cruisers
Old 29 Oct 2011, 04:53 pm
UptownSport's Avatar
Default Re: oil leaks
Just spill most likely.
If head gasket were leaking oil, it'd be in rear, where you can't see it.
Old 29 Oct 2011, 04:55 pm
...and if it was the valve cover gasket, the oil would go down, not on top of the cover. Who does your oil change. If it's one of those quick lube places, it's more likely what UptownSport has said.
Old 29 Oct 2011, 05:55 pm
mdfrodolives's Avatar
Fancy, make sure you unscrew your oil cap and then screw it back on until you hear it click once. Don't over-tighten it. Then clean up the oil from the area that concerns you.
Check it again in a week.
Tim
Old 29 Oct 2011, 06:50 pm
And if you look at block, there's only one spot oil's pressurized near periphery:
(Left rear, rest are just drainback holes w/o pressure)
Early headgaskets would frequently leak there; now with MLS Headgasket, there's never oil leaks,
just coolant.
Old 29 Oct 2011, 07:48 pm
Also check the condition and color of it. If it is fair that clear clean oil (when and if someone did oil change) and if blk dirty. Leakages would be the dirty kind but also have dirt stuck to it if was old.
have slow leaks too alycemaysk@aol.com Wheels, Tires, Suspension 12 13 Sep 2012 04:48 am
Water Leaks? Silverbagger Welcome New PT Cruiser Members 1 18 Sep 2011 06:06 pm
Door (?) Leaks in My Cruiser VaBchFrank Northeast PT Forum 3 09 Feb 2011 10:16 am
2005 pt leaks Mr.J General PT Cruiser Discussions 4 20 Dec 2005 07:12 pm
Gas Milage and Leaks Lightbringer General PT Cruiser Discussions 3 02 Aug 2004 01:26 pm
