Error Codes P1388 and P0320
Old 30 Oct 2011, 04:23 pm
Default Error Codes P1388 and P0320
Hi
I recently boughta 2001 2.0 Automatic on which the head gasket blew as I was bringing it home.
Replaced the head gasket, skimmed the head rebuilt the engine and now it won't start. No fuel or spark.
I used the ignition key method and got the codes P1388 and P0320 of the speedo panel.
Can anyone point me in the right direction for a fix or do I have to tow it outside and burn it. It's starting to wear me down.
Old 30 Oct 2011, 05:04 pm
Default Re: Error Codes P1388 and P0320
Hopefully you mean 2.4 ltr as the 2.0 is only made overseas and the code breakdown might mean something different.
P1388 might be just a fuse for the ASD (Auto Shut Down) relay. It's No'# 13 fuse in the PDC (Power Distribution Center) in the engine compartment.
P0320 means there's no signal detected from the CKP (Crankshaft Position sensor) while cranking so you might want to replace that. It's right above the oil filter in the back of the engine.
Talk about bad luck. Blowing the head gasket on the way home from buying it?
2 error codes at once heshdog Tech & Performance Forum 9 02 Oct 2011 05:07 pm
error codes??? Turboguy85 Turbo Performance 2 22 Sep 2010 05:15 pm
Error codes mr.troy Tech & Performance Forum 3 16 Jan 2007 04:26 pm
ERROR CODES Kirby General PT Cruiser Discussions 4 24 Oct 2006 03:15 am
