TCM or transmission problem.
Old 30 Oct 2011, 10:10 pm
Default TCM or transmission problem.
My wife's 03 went crazy yesterday. She said it started shaking while on the X-way, so she pulled over. When I got there, it would start fine and even drive slowly in first for a minute or two before slipping out of gear. It would shake if I gave it gas. Wouldn't go into 2nd but it didn't die. Got a few codes. P0131, preconverter O2 sensor low input voltage. P0440, P0441 and P0456, all about evap system failure/leak. I think those are unrelated to the problem. My wife said the check engine light came on a couple days earlier and gave her a code P0700, then the check engine light went off. I didn't get that code when I ran them. 0700 is a transaxle control system malfunction. Could this be a loose connector to the TCM? Maybe a bad TCM? I never got a P0604 or 0605, indicating a TCM fault. What could this be?
Old 31 Oct 2011, 01:11 pm
Default Re: TCM or transmission problem.
Well, I pulled the damn thing out. That was probably a rash decision, but I was hoping I would find something obviously wrong with it. The connector did have some wiggle to it, which seems wrong. Earlier this summer we had an overheating problem. I flushed the radiator and it's been fine since. Could some moisture have gotten in and fouled that module up? Do you think I'm way off track here? I never got a TCM fault code, but maybe it just had an intermittent power interruption.
Old 31 Oct 2011, 01:21 pm
Try disconnecting battery for a while - it resets all electronics and would rule out a temporary glitch.
Transmission problem? PTFORME Tech & Performance Forum 4 12 Aug 2010 04:55 pm
transmission problem? if so what next? yvetteski General PT Cruiser Discussions 4 25 Feb 2009 01:42 am
Transmission problem perhaps? banddork123 General PT Cruiser Discussions 2 09 Oct 2008 09:05 pm
Transmission Problem...I think??? QuickPT Tech & Performance Forum 5 28 May 2005 02:09 am
transmission problem dbraveman General Turbo Discussions 12 09 Mar 2004 11:44 pm
