Grinding noise while slowing down, whirring noise while speeding up
Old 31 Oct 2011, 09:42 am
Default Grinding noise while slowing down, whirring noise while speeding up
I have a 2004 PT Cruiser, Touring, about 130,000 KMs and I've had a transmission leak that took three visits to be fixed in the last six months.
Not sure if this is related to the leak, but the car has started to make a grinding noise when I drop below 40KM/H. It's not just brake related - if I don't brake and just slow down, it makes the same noise (but not as loud). When I brake from a high speed the sound is much louder.
When I accelerate, it makes a whirring noise until over 40 KM/H. There's no shaking and no other odd noises. It's fine at high speeds and is fine when I start it.
The noise is loud - it sounds as if I were driving over a snowbank or I'm dragging something.
Any ideas?
Thanks
Old 31 Oct 2011, 01:01 pm
Default Re: Grinding noise while slowing down, whirring noise while speeding up
Sounds like a wheel bearing. Try turning the wheel - if noise changes, it confirms it's a bearing.
Old 31 Oct 2011, 01:19 pm
Thanks quicksilver don -
The noise doesn't happen when I turn the wheel, only when I slow down or speed up. I took it on on the highway after the noise happened and did some turns at rather high speeds and no noise, until I got off the highway and slowed down below 40 KM/H.
Old 27 Nov 2011, 09:41 am
Maybe a motor mount, some plastic supports, not too expensive
Mine did that too, took it to mechanic and turned out to be that thing
Old 27 Nov 2011, 09:55 am
I'm betting wheel bearing. That is the way mine sounded too. By the time I changed it I had to replace the hub as well.
Old 27 Nov 2011, 10:15 am
SCBluePT's Avatar
Yep,sounds like a wheel bearing.You usually cant hear them at high speed.
Tags
engine, grinding noise, whirring noise
AC Fan grinding noise shonenknife Tech & Performance Forum 6 27 Jun 2013 05:59 pm
Whirring noise after cold start? danielgermain73 General PT Cruiser Discussions 4 02 Feb 2012 05:17 pm
whirring whistling noise fancy Tech & Performance Forum 1 29 Oct 2011 05:58 pm
Grinding noise. PtOnAir Tech & Performance Forum 6 10 Jan 2011 09:40 am
Grinding noise SmittysGold Tech & Performance Forum 21 20 Oct 2008 07:25 am
