Belt squealing
Old 03 Nov 2011, 10:55 am
Default Belt squealing
In my 05 base model I have a belt squeal only when my foot is on the gas. Cold and warmed up. My dad own the car before me and he said all the belts have been replaced. Do any of you able to help me out. I hear it from the passenger side. Thank you guys!
Old 03 Nov 2011, 11:06 am
mdfrodolives's Avatar
Default Re: Belt squealing
The belts may have been replaced. But they may not be adjusted properly, or the serpentine belt adjuster may be shot.
Tim
Old 03 Nov 2011, 11:30 am
Is it possible to check that stuff myself?
Old 03 Nov 2011, 01:02 pm
Tim's right but more than likely it's the alternator belt because there's no tensioner and it's up to whoever replaced the belt to tighten it up properly.
If you want to look yourself, take the passenger front wheel off and take off the inner fender. That gives you sight and access to both belts. Do you know the proper way to tighten and test the belt?
Which bolt is the tensioner bolt on the alternator?
Old 03 Nov 2011, 07:32 pm
compdr59's Avatar
You may have a worn idler. It's part of the tensioner and can be replaced by itself. If you remove the tension off the P/S and A/C belt, rotate the idler. The bearing may be shot.
Original Owner 135k
Loud squealing when turning left dllbzrose Tech & Performance Forum 5 24 Oct 2011 12:02 pm
Drive Belt (PS/AC) Belt Tn_Hogger Tech & Performance Forum 9 11 Aug 2011 09:20 am
Belt change help - Not timing belt skfloyd Tech & Performance Forum 2 23 Apr 2010 11:23 am
Knocking and Squealing Sounds. TrickyMcTrickPants Tech & Performance Forum 2 05 Dec 2009 07:35 am
New Drive Belt Still Squealing - Now What? falconut Tech & Performance Forum 5 25 Mar 2009 04:18 pm
