Please help!!
Old 03 Nov 2011, 06:40 pm
Default Please help!!
I'm ready to explode. 2001 pt, motor trash, put in 2003 engine. I get conflicting information that it won't work. some say it will. Car won't start. 2001 computer won't read 2003 engine sensors. Is that true? Am I screwed? Can you swap in a 2003 motor into 2001 without having to change computer and engine wiring harness?
Old 03 Nov 2011, 08:47 pm
Default Re: Please help!!
Now I'm not sure about this, but I think I remember reading about this on PTCrew, that if you swap the engine you have to have or ECM reprogrammed. I'm no expert, especially on pre-'06 models, but I think that sounds logical.
Old 04 Nov 2011, 04:36 pm
UptownSport's Avatar
Is crank sensor behind starter or above oil filter?
Old 06 Nov 2011, 10:39 am
It's above oil filter. In 2003, they moved it to front of car. That's the only difference.
Old 06 Nov 2011, 11:34 am
I think the EGR pipe in the back of the upper manifold is different. I believe Chrysler re-engineered something and did away with the pipe altogether in 2003. Before that, the EGR pipe goes from the back of the upper manifold down to the EGR valve.
Old 06 Nov 2011, 11:41 am
thats correct because i believe after 03 it went to driver side of the engine. and with doing work to my pt last night the upper intake manifold still has the whole there for the egr valve to bolt in.
Old 06 Nov 2011, 02:30 pm
So the engine you had had the crank sensor above the filter,
The CURRENT engine has it behind the starter? Correct?
You've put a NGC engine in place of a non NGC engine.
Don't think that's going to work.
