2001-2007 PCM Programming TSB
Old 07 Nov 2011, 08:34 pm
Default 2001-2007 PCM Programming TSB
In this bulletin:
DISCUSSION:
ALL LISTED VEHICLES EXCEPT SEBRING COUPE/STRATUS COUPE (ST),
CROSSFIRE, AND SPRINTER.
When a Powertrain Control Module (PCM) is replaced on vehicles equipped with the Sentry Key™ Theft Deterrent System, it must be initialized to properly function with the anti-theft module. This is accomplished at a Chrysler Group Dealer by using the DRBIII® or StarSCAN™ Scan Tool to enter a PIN number.
When the PIN number is not available from the vehicle owner or a Chrysler Group Scan Tool(s) is not available this can be accomplished by writing the Vehicle Identification Number (VIN) into the PCM using an after-market scan tool with a "VIN Write Function".
You can download this TSB here: TSB_08-030-06_RevA.pdf
Quick screen shot:
Engine swap 2001 to 2007 boerter Tech & Performance Forum 7 16 Feb 2014 11:08 am
2001 Rims fit on a 2007? falconut Wheels, Tires, Suspension 4 13 Nov 2010 02:33 pm
Re-programming the PCM? alceryes General Turbo Discussions 8 06 Jun 2010 11:51 pm
Online Parts Manual's 2001 - 2007 Candyman Tech & Performance Forum 0 03 Apr 2009 04:49 pm
Programming the ECU Deathstar Tech & Performance Forum 2 19 Apr 2008 10:20 pm
