Changing front brake caliper right now - NEED HELP.
Old 13 Nov 2011, 11:48 am
Default Changing front brake caliper right now - NEED HELP.
Installing new drivers side brake caliper since mine seized and would not compress.
Anyone know the torque spec for the hose-to-caliper connection? I want to make sure I get those crush washers right and not have any leak.
2001 PT Cruiser, Base Model, Dark Blue
NGK GP-Series Platinum Plugs, Autolite Wires
116k, Avg. 22+mpg mixed driving
Old 13 Nov 2011, 02:11 pm
UptownSport's Avatar
Default Re: Changing front brake caliper right now - NEED HELP.
if you use new washers it doesn't take much.
re-using washers will take alot, and sometimes will never seal.
I've never used a torque wrench; if it don't leak under pressure; it's good!
Old 13 Nov 2011, 02:19 pm
That's the banjo bolt, the torque spec says 24 newton meters, or 18 foot pounds, or 210 inch pounds. See graphic below:
Old 13 Nov 2011, 03:29 pm
Thanks guys, but I F'd it up. Went too far and broke the banjo bolt. It didn't take too much force at all. I was really surprised when the head popped off.
Anyway, I will call the dealer for a new banjo tomorrow and will torque correctly at 18lb.
Old 13 Nov 2011, 04:55 pm
I'd guess they are common to many Chrysler (and likely other) vehicles as IIRC, Bendix makes PT Brakes.
Go to U-Pull and grab one off a C-Van.
Need to replace front brake caliper tubularbel General PT Cruiser Discussions 7 20 Sep 2011 02:06 pm
Beep when car starts moving after changing front brake pads. No error code. ineptspelr Tech & Performance Forum 1 07 Sep 2011 01:47 am
Cable from front of Brake Caliper Coop Tech & Performance Forum 17 14 Oct 2010 09:05 am
What Brake Caliper Color? amazingarthur Exterior Accessories Forum 21 29 Jul 2004 11:20 pm
Brake Caliper Paint? PTRON General PT Cruiser Discussions 3 17 Feb 2003 02:11 pm
