Timing belt instilation problem.
Old 14 Nov 2011, 05:13 pm
Default Timing belt instilation problem.
ok, i could use some help. im a student at a very well known automotive school and im having some problems installing the timing belt on the 2.4. I have a 30 year ford master tech helping me on this job as well and we are both stumped. This car came to me with a cooling leak, we found that the water pump gasket was leaking so we replaced the water pump, all o-rings, all coolant hoses to the radiator and the heater core, and the idler and tensioner on the 2.4. my problem is this pt i have is a 2001, and i have bought the updated timing cover and tensioner for this car, and it is installed properly according to OEM repair procedures. When i have all the timing marks lined up and try to place the timing belt on the engine, even with the tensioner backed off all the way we still can not get the timing belt to fit even with two people. i have measured the old tensioner and it is a full 10th of an in smaller in diameter than the new updated tensioner and that feels like all the clearance that we need to place this timing belt on the engine. any help would be greatly appreciated as both me and the tech helping me are stuck.
Old 14 Nov 2011, 05:28 pm
Default Re: Timing belt instilation problem.
The secret to this trick is to either take the belt and "strech" it around a spare tire, or leave it out in the sun for a hour or two allow it stretch itself out.
BY NOT MEANS APPLY ANY HEAT.
Old 14 Nov 2011, 05:51 pm
you know that is the dumbest thing i have seen on a car, but i was doing that just as you posted your reply. letting the belt cook under the hood of the car. im down here in az, and today its 72, but when i tried putting the belt on it was this weekend when it was about 60. after letting it cook, and then trying to stretch it out between my hands and my steel toe, the belt went right on, so put alot of tension on it and let it set, and ill take it off when the sun goes down. as a student it sounds stupid but its basic physics that i over looked. thank you for your help
Old 14 Nov 2011, 08:36 pm
compdr59's Avatar
Since you have the new tensioner, you may not have it in the right position for belt installation. Here is a quote for the removal process. Make sure you are in the removal location before attempting installing the belt.
Insert a 6 mm Allen wrench into the hexagon
opening located on the top plate of the belt tensioner
pulley. Rotate the top plate CLOCKWISE
until there is enough slack in timing belt to allow for
removal.
Original Owner 135k
Old 15 Nov 2011, 10:27 am
Its one of those things that only takes once to get it right and youll never forget it... LOL. Glad you got it on.
A different kind of Timing Belt problem Quicksilver Tech & Performance Forum 7 15 May 2011 03:48 pm
Problem after timing belt replacement. britten44 Tech & Performance Forum 7 09 Aug 2010 07:17 pm
Changed timing belt, New Problem starrlyte99 Tech & Performance Forum 2 27 Apr 2010 07:13 pm
02 2.4L timing belt problem ronwins3 Tech & Performance Forum 18 15 Dec 2008 08:57 pm
Fixed timing belt now another problem EvilWRX Tech & Performance Forum 1 13 Feb 2007 09:35 am
