harmonic balancer (or what ever yall call it)
Old 16 Nov 2011, 11:06 am
mdskinner731's Avatar
Default harmonic balancer (or what ever yall call it)
ok.. bought the new harmonic balancer for the pt (main crank pully) and cant seem to get it installed??? any suggestions or tricks y'all use to install it??
pic is of new (on the left) ond old (on the right)
the new is called a "performance" balancer??? but same weight & size ?? price was right $83 so i got it
if it moves and not supposed to... duct tape!!!
if it dont move and is supposed to... WD-40!!!
~* the problem with america is warning labels.... take them off of every thing and eventually the stupid people will die off... *~
Old 16 Nov 2011, 11:10 am
Default Re: harmonic balancer (or what ever yall call it)
I just used a little oil when installing it and push it in with the bolt. btw, what was wrong with the original?
Old 16 Nov 2011, 12:25 pm
jdpersico's Avatar
You have 2 options if you don't have the proper tool.
1st.(Better) Get a longer bolt with a big washer (I think the Neon's bolt is perfect) and start to tighten. If my memory doesn't fail it's a 10 mm /1.75 bolt, and you'll need about 1 inch and a half longer bolt
2nd.(Polemic) Place the balancer without the bolt. Put a long 18 mm socket and hit with a rubber hammer until your bolt can be tightened. The socket is used to get an uniform distribution of strengh when you're hitting, once you can tight the bolt, proceed with the tighten.
To be honest, I used a regular hammer with no problems but there is concensus that it's inappropriate. So don't use a metal hammer.
Old 16 Nov 2011, 02:18 pm
oh yea... i kno all about not using a metal hammer... lol but i tried the rubber hammer trick already with no avail
my old center hole got buggered up on the old one wen i took it off of the engine. its kinda egg shaped if you look closly possibly not a darn thing wrong with re-using it but oh well
Old 16 Nov 2011, 04:25 pm
rcktpwrd's Avatar
go to AutoZone or any parts store and rent the balancer tool, it's free.
Joel
www.rcktpwrd.com
Havn't forgotten about yall. Just been really, really busy Candyman The Detail Shop 12 25 Oct 2011 05:15 am
harmonic balancer mdskinner731 Tech & Performance Forum 10 15 Sep 2011 09:04 am
harmonic vibration rszappa1 Wheels, Tires, Suspension 17 15 Feb 2006 11:39 am
Howdy Yall ! ATLPTGT General PT Cruiser Discussions 4 14 Jan 2005 08:28 am
A solution to the "harmonic drone" problem Gary04GT General Turbo Discussions 12 19 Jun 2004 10:29 am
