code P0302
Old 16 Nov 2011, 08:59 pm
mdfrodolives's Avatar
Default code P0302
Hello, everyone,
My wife says she got a check engine light today, and sure enough, when I checked it out, that was the case.
I checked for codes and got a P0320 (cylinder 2 misfore detected).
Anyone know the most common reason for throwing this code?
She said the engine ran a little rough for about a block this morning, but other than that, no difference was detected.
Thanks,
Tim
Old 16 Nov 2011, 09:42 pm
rcktpwrd's Avatar
Default Re: code P0302
Could be a bad spark plug and/or plug wire
Joel
www.rcktpwrd.com
Old 16 Nov 2011, 10:12 pm
Take the plug wire from #2 and put it on another plug to see if the code changes. One of the biggest problems for a single code like that is a small vacuum leak on the intake around where it attaches to the lower intake or on one of the seams.
Old 17 Nov 2011, 12:17 am
Thanks, guys!
This Friday I'm going to pull the plugs, anyway--and check the plug wires, too. But, Crewzin, when you mentioned the vacuum leak at the "intake", do you mean one of the four seals where the upper intake manifold meets the lower intake manifold? If so, this could be a problem since I've removed the upper intake manifold several times (although, only three times), and never installed new seals. I did this because I was under the impression that one could re-use those seals up to ten times. And I torqued the manifold bolts to 105 inch pounds, like I was supposed to.
I'll clear the code and try switching the plug wires around--after I check the plug, itself. I can then assume the problem is with the plug wire if the code changes to the other cylinder. since I have to raise the upper manifold, I'll install new seals, while I'm at it.
It's odd, though. I changed those plug wires to "Bosch", no more than six thousand miles ago--and never a problem until now..
I forgot to mention that I also got a P0325 code (Knock Sensor circuit problem). But I assumed that if I had a "firing" problem with one of the cylinders, the Knock Sensor code would be thrown automatically.
Anyway, I'll keep you guys posted.
Tim
Old 17 Nov 2011, 12:19 am
Wait a minute! Crewzin, you also mentioned a vacuum leak at "one of the seams".
What "seams"?
Tim
Old 17 Nov 2011, 07:04 am
The actual seam where the upper manifold comes together. It's made in a couple of pieces and put together so a small gap/pin hole can cause air to be sucked in.
Yes, I was referring to the area where you have the 4 small red rubber washers that are between the upper and lower manifolds. They can be used over and over (3rd time for me too) but you have to be very careful no foreign material accidentally got in there and inspect the rubbers rings really good.
Rough idle / stalling
Old 17 Nov 2011, 08:49 pm
Crewzin, thanks for the input. I'm wondering how on earth I'm going to find a tiny leak at the seams--at this point. But I assumed that since the P0302 code was for the number two cylinder only that you were referring to a leak at the upper-to-lower manifold (red) seal that surrounds the manifold opening that directs air to cylinder number 2, and this would affect the firing at the number 2 cylinder.
Also, are you saying that the leak (if there is one at the seam) would be at the seam directly near the number 2 cylinder--so that it affects the air flow at that cylinder? If so, I can understand how that works. But if the leak is, say, way over on the side nearest the number 4 cylinder, then could it affect the number 2 cylinder, as well? In that case, I'm a little stumped.
Well, either way, I'll inspect the manifold very closely when I change out the plugs and wires again.
By the way, my wife told me today that the check engine light came on in the morning--but not when she went to lunch or drove home after work. The only thing I did last night was unscrew and screw back the fuel-filler cap.
I'm going to unhook the battery cables in a minute and hook them back up to erase the codes--and see how that goes.
Thanks again.
Tim
Old 17 Nov 2011, 09:11 pm
Tim,
Yes, any leak would have to be around cylinder#2 for that code to show up.
Old 17 Nov 2011, 10:58 pm
Thanks again, Crewzin!
I uncoupled the battery terminals and hooked them back up. The codes disappeared. At least I think they did. I got nothing this time but the odometer reading. No "Done", at all.
I'll do the key dance again tomorrow after the wife has driven the PT to work and back. I have a feeling the codes will show back up again.
Tim
Old 18 Nov 2011, 11:20 am
You should always at least get "done".
Is idle okay? vacuum leak usually causes a rough idle. I'd also throw a bottle of Lucas injector cleaner in in case the injector is clogged - and it's like chicken soup - can't hurt.
CEL code help?? 05pt Tech & Performance Forum 11 08 Sep 2010 10:51 am
Code ? 1lowufo Tech & Performance Forum 1 25 May 2010 06:25 pm
code 352 coco1476 Tech & Performance Forum 5 18 Jan 2010 05:19 pm
Code Help! 1lowufo Tech & Performance Forum 1 21 Aug 2004 07:03 pm
