Oil Pressure Light on
Old 17 Nov 2011, 05:26 pm
bassahaulic52's Avatar
Default Oil Pressure Light on
My low oil pressure light came on today while I was slowing down.
I checked the oil, and it was low bit certainly within range. I decided to drive to O'Riellys to get some oil. I noticed during the drive that after I reached say 1,500rpm the light would turn off, ans only turn back on as I stopped. But once idling it would stay on unless I reverse it.
After I added 1 quart of oil, I drove. Same thing. Added a 2nd quart. Samething. Checked oil level. Right below full now. I did notice as well that it takes a second longer for the light to kick on now.
I'm letting it sit to see if the oil just need to get through the top down into the pan.
Thoughts?
~Drew Jones
Team SSA
Team Sundown
Team Southen Hertz
2001 PT Limited 70k miles.
Sound Solutions Audio ZCON
DIGITAL DESIGNS True to the source
PRS <3
┌∩┐(◣_◢)┌∩┐
Old 17 Nov 2011, 05:35 pm
Default Re: Oil Pressure Light on
Thoughts? How the heck did you let it get over two quarts low? It only holds 5 with a filter! What do you consider "within range" ?
You'll be lucky if only changing the oil sending unit with solve your light problem. Many owners have had to change it.
Old 17 Nov 2011, 06:58 pm
I agree 100%. 2 quarts low is certainly NOT within range.
It's most likely the sending unit, but there is still a possibility that the oil pump is weak and your oil pressure actually drops off at idle speeds.
Look into this immediately. If it's the sending unit, you're in no danger, but if the presssure is actually dropping off, you want to fix it before it costs you an engine.
-Chris
Old 17 Nov 2011, 07:29 pm
Welcome back Chris.
Old 17 Nov 2011, 09:08 pm
My mistake, I got it out of order. I checked the oil, AFTER I added the first quart. So then it was in range.
I have driven it a little since adding oil and it hasn't done it since. I'm still going to drive the GF's Mustang for a few days so I can trouble shoot it.
~Drew Jones
Team SSA
Team Sundown
Team Southen Hertz
PRS <3
┌∩┐(◣_◢)┌∩┐
Oil Pressure Light? thetunesguy General PT Cruiser Discussions 26 27 Oct 2016 06:37 am
Showing ABS light, Brake light, Traction light on Dash fox50h Tech & Performance Forum 19 18 Feb 2014 11:40 pm
oil pressure light sticks on nomad327 Tech & Performance Forum 2 22 Nov 2010 06:54 am
Oil pressure light problem - just replaced cam sensor jeremyrocksursox Tech & Performance Forum 5 02 Jul 2010 10:22 pm
Car Sometimes won't start (oil pressure light & Engine Light) gerardio Tech & Performance Forum 6 18 Jul 2008 08:22 am
