Bypass MFS & wire fogs directly to headlights? Possible or Crazy?
Old 18 Nov 2011, 10:15 am
TallahasseeGT's Avatar
Default Bypass MFS & wire fogs directly to headlights? Possible or Crazy?
MFS went out in my 5spd GT. Ive already replaced the MFS in my ATX GT and I dont want to shell out that kind of money again. I think I am able enough to repair the switch, but would just rather not if I can get around it.
Instead I was hoping I could just wire them directly to my headlights somehow. That way whenever the headlights are on, the lower fogs are on too. And same for when they are off. Is this possible?
Can I bypass the MFS this way? Or would I have to disconnect the fogs from the MSF and wire in an aftermarket switch somewhere in the cabin?
Before you ask If Ive searched the forum, yes. Ive done a little research and have somewhat found my answer. Id just like to be reassured.
I also found a very very little write up of someone who bypassed the MFS and mounted an aftermarket Chevy switch from the 30's or something into the spot that use to carry a power outlet. I'd rather not go that route if I can avoid it. But if need be I will, however a better write up would be nice.
Anyone got some $0.02 they could throw my way on this subject?
2004 PT GT 5-Speed: Traded for a 2004 Mustang GT 5-Spd
2004 PT GT ATX: (Daily Driver) Airbox Mod w/ K&N Filter, Custom Intake Pipe, HKS BOV, Dejon Powerhouse UIP, Mopar Stage 1 PCM, 3 Guage Pillar Pod, Boost Guage, Oil Temp Guage, Air Fuel Ratio w Wideband, Reinforced OEM Motor Mounts, Ceramic Pads, Flameball Shifter (Ivory w/ Red Flame), Kenwood 12" w/ 800w Sony Xplod
Old 18 Nov 2011, 10:57 am
Default Re: Bypass MFS & wire fogs directly to headlights? Possible or Crazy?
You can get a relay and trigger it off the low beam wire. Not easy accessing wires in the harness and you need to find a home for the relay. I'd get heavy wire and put in an inline fuse and come right off the battery, thru relay to the fogs and disconnect the existing wires at the fogs.
Old 18 Nov 2011, 12:12 pm
Here is how to put a relay for the foglights. Is called "Relaying Fog Lights" in the Mod Bible.
PTCrew.com - Learn it or Burn it.
Old 18 Nov 2011, 01:00 pm
harrym's Avatar
That would be sanatanadharma - here's a page from his blog showing what he did - http://2004ptcruiser.shutterfly.com/89
Old 18 Nov 2011, 04:03 pm
Will this make my fog light symbol in my dash go off too?? I hate that pesky little green light.
Old 18 Nov 2011, 05:26 pm
If you run your fogs directly to another switch you will not get any indication on your dash. After replacing my MFS, I ran my fogs to a relay but left them on the MFS for control. I get the indication when I turn them on, but there is no load now going through the MFS so it will last longer.
Old 19 Nov 2011, 01:07 am
The PTcrew.com post instructions will not disable the fog light indicator on the dash. As Chromenut writes, the green dash idiot light will illuminate as long as you continue to use the multifunction switch to control the fog lights, whether directly or through a relay. A separate switch wired into the circuit as I did, to replace the multifunction switch (using the same wiring) will also leave the green light functional.
To disable the green light, you need to cut one of the two light blue wires from pin #14 at the multifunction switch; and it has to be the correct wire; the one going to the instrument panel.
This light blue wire can also be cut at the black C2 instrument panel connector (pin #1).
Old 19 Nov 2011, 09:39 am
I need to do something similar on my cruiser. Thanks for posting the links in this thread.
I think this needs to be moved to the tech section so that it can be found easier in the future.
Old 19 Nov 2011, 10:59 am
Here's another write-up like we have but it's from the UK Cruisers site. The person that was having problems said he fixed his MFS in about 20 minutes.
UK Cruiser Club :: View topic - Fog light problem - fixed!
Old 20 Nov 2011, 09:03 pm
You can bypass the MFS as the switch wears out over time. You'll need a switch to put in the dash under the radio next to the rear wiper washer in the 2004. You'll need a switch, a roll of wire, soldiering iron, soldier, heat shrink tubing, figure for about 4 to 5 feet of line approx. (it has been a year or so since I did this) This is your best bet to avoid running your battery down. Oh do not forget to find a wiring schematic for the lights and MFS. The post above may be right on the exact number line to cut but you will basically split that particular wire and run the wire to the switch. Also wrap the full length of the wires with so heat covering like split loom tubing. Use the heat shrink to cover the soldiered connection and avoid sparks and popping fuses. (but you knew that) I hope this helps. 2004 Chrysler PT Cruiser TE 2.4, Auto, AC, 165k still running strong, 20-24 mpg, with K&N filter, and aftermarket transpan with drain plug for less mess. Check Advance Auto for the transpan.
Directly from Brazil, Pt Cruiser Ballet, This only happens here edi PT Cruiser Videos 4 01 Feb 2012 04:41 am
Multifunction Switch 04 PT w/fogs CYCLONE_06 Classifieds: Want To Buy 0 22 Nov 2009 01:43 pm
Any one put factory Fogs on car that did not have them??? ginuwine Exterior & Interior Styling 19 08 Oct 2009 04:26 am
Help my dad's Fogs won't turn off!!! Atrus1212 General PT Cruiser Discussions 6 04 Jun 2009 12:46 pm
New Fogs CYCLONE_06 Exterior Accessories Forum 8 25 Aug 2008 08:10 pm
