Radiator drain plug
Old 19 Nov 2011, 11:52 am
Thumbs down Radiator drain plug
I just drained some anti freeze from my radiator,and it won't stop dripping. Has any one had this problem.The valve appears to be in the right position,but it still drips.Will tightening it more help?
It's 2003 limited .I just finished putting radiator fan assembly in it.
Old 19 Nov 2011, 01:01 pm
mdfrodolives's Avatar
Default Re: Radiator drain plug
Bogaz, I was unable to ever get the drain plug to open enough to drain. I, too, have a 2003 Limited. To drain, you're supposed to turn the plug one-quarter counter-clockwise, then clockwise one-eighth--and pull straight out. But the design is absolutely stupid, and is faulty. These guys never heard of threaded draincocks, I guess.
So basically, the draincock only turns a quarter turn, no matter what. So the area that you grab should end up in the 12 o'clock position when tightened back up to the closed position.
If if continues to drip, you might have cracked the o-ring, or the plug, itself.
I had to take off the lower radiator hose, to drain.
Tim
Old 19 Nov 2011, 07:56 pm
Smile Re: Radiator drain plug
thanks for the reply.I got under it again and turned it a little more and it stopped.I didn't know about pulling it out,but it drained,but I could pee faster than it came out.I got the job done anyway.Thanks again
Old 19 Nov 2011, 11:13 pm
Dino's Avatar
It has an O ring on it that might be bad, which can be replaced. The only place I was able to find the petcock was the dealer and it was 12 at one and six at another.
Old 11 May 2012, 10:32 am
I wasn't too sure if I needed to start my own post, but it seemed like a good idea to ask under this one: I just installed the radiator fan assembly (which couldn't attach correctly as the previous owners had a mis-shappened radiator that prevented it's left side from screwing into the radiator) and after draining the radiator, the drain plug won't close allowing fluid to seep out. I've tried inching it left and right, pushing it in while doing so; And after 4 hours, still no luck. Before I subject my hands through another trial, I wanted to know if there's anything i'm missing, any advice that could be given, anything I could try before buying a new radiator. Thanks in advance!
Old 11 May 2012, 10:45 am
If you heeded the advice given above and it still won't stop leaking you might want to try some plumbers tape. It's supposed to go onto threads but if you put a couple rounds on the tapered edge of the pet-cock, just maybe that will take up enough space to stop the leak.
Old 11 May 2012, 11:00 am
You guys never cease to amaze. Never, ever thought about that. I'm going down to my local store soon after work. Good looking out homie!
Old 11 May 2012, 11:52 am
Is that a compliment?
Old 11 May 2012, 12:18 pm
Lol! Yeah! Homie= amigo, bro, friend, compadre, etc.
Old 11 May 2012, 01:05 pm
Different generation.
can't find radiator drain plug notarobot General PT Cruiser Discussions 1 28 Mar 2010 10:40 am
How to replace radiator drain plug? hotdog789 Turbo Performance 2 22 Feb 2010 11:57 pm
Radiator drain plug Mapper Tech & Performance Forum 16 15 Jul 2009 08:06 pm
oil drain plug tagreen95354 Tech & Performance Forum 14 05 Feb 2006 09:37 pm
Drain plug DREAM2 General Turbo Discussions 11 06 Jul 2004 10:14 am
