Compression
Old 19 Nov 2011, 03:07 pm
Default Compression
Hi,
First post here eh ., I have an 02 PT 2.4 and # 3 has 5o PSI compression compared to the others 180 or so. Did the oil leak down test and the compression didnt go up,, seems like it may be a valve ugh.
Took of the cover and noticed one of the exusat lifters in #3 looked a little weird. Replace the lifter but still no compression.. Anybody??
Old 19 Nov 2011, 06:26 pm
UptownSport's Avatar
Default Re: Compression
Can you live with how it's running??? Oil consumption?
If so, forget the numbers and drive it!
otherwise, a valve or two's pretty cheap, sounds like you have enough acumen to replace a valve.
Old 19 Nov 2011, 07:24 pm
So your in agreement its probably a valve? I'll tear it off tonight or in the morning
Old 19 Nov 2011, 07:42 pm
mdfrodolives's Avatar
If it were a ring problem, your compression would have risen when you put oil down the hole.
Tim
Old 19 Nov 2011, 08:05 pm
Tim
Indeed. These 2.4 inherent to valve problems?
Old 20 Nov 2011, 01:57 am
No. I'd have no idea why they would fail, unless they had a bad vendor for a short period-
Here's an '06:
There's tons of '95 with hundreds of thousands of miles that have original valves- No reason for yours to fail.
Old 20 Nov 2011, 08:39 am
Here's an '06:
Thanks,, this is an 01 however should be the same. Might replace that injector too perhaps it was running lean, will fins out today
Old 20 Nov 2011, 04:39 pm
Looks familiar, Now, whats the cause?
Old 20 Nov 2011, 07:22 pm
Jesus.
IDK.
'01 went to 3-groove valves- This allows valves to rotate.
Perhaps they rotate too much.
I'd have a machinist inspect it- see if seat wore into valve faces excessively.
Old 21 Nov 2011, 09:30 am
Good idea on injector - lean would do it - if you ate a hole in piston, you'd have white fog exhaust.
Compression problem 04stocker General PT Cruiser Discussions 4 17 Apr 2011 11:08 am
The no compression engine PTProblems Tech & Performance Forum 2 01 Apr 2011 09:15 pm
engine low on compression LoWandSloW Tech & Performance Forum 7 02 Jul 2007 09:58 am
compression fittings Punch Exterior & Interior Styling 10 11 Nov 2003 10:36 pm
compression fittings? Punch General PT Cruiser Discussions 4 02 Oct 2003 12:59 pm
