Head gasket leaking
Old 20 Nov 2011, 12:07 pm
Unhappy Head gasket leaking
I believe I have a small leak through my head gasket.It shows no sign of it now,but a couple of times it was missing when it was cold.Scanner showed #3 cylinder was misfiring.My question is,is that enough to suspect a head gasket?And can I use some head gasket sealer?I can't afford to replace the head gasket.Oh,and there is no white smoke. It is a 2003 limited,all stock.
Old 20 Nov 2011, 12:38 pm
Default Re: Head gasket leaking
It could also be a bad plug wire, bad plug or fuel injector. It's a leap to think it's a cracked head gasket without further investigation.
How to Diagnose a Blown Head Gasket | eHow.com
Old 20 Nov 2011, 02:55 pm
Unhappy Re: Head gasket leaking
It only does that,misfire,when it's cold.And, I replaced the wires/plugs recently. My father,a mechanic,thinks water is leaking into the #3 cylinder,causing it to misfire.It seems to me that water would leak in there,and stay until the engine burns it out. just a theory at this point.
Head Gasket Fix? Tn_Hogger Tech & Performance Forum 9 25 Aug 2011 12:10 pm
head gasket...? him72787 General PT Cruiser Discussions 2 21 Jun 2011 05:07 pm
WARPED HEAD / SCORED CAMSHAFT / BLOWN HEAD GASKET amadeo Tech & Performance Forum 5 12 Apr 2011 01:03 am
Leaking Oil/ head Gasket? hellobubbles Tech & Performance Forum 4 08 Mar 2011 04:23 pm
head gasket how to tell if bad BeagleDad Tech & Performance Forum 18 18 May 2010 09:53 pm
