p0304 misfire code
Old 20 Nov 2011, 04:10 pm
Question p0304 misfire code
I have a 07 pt cruiser CHECK ENGINE light comes on. Code 0304 changed plugs and wires. reset light. Drove the car. Went about 10 miles, stop at a light, car set idling, CHECK ENGINE light came on. Check code again sure enought 0304 comes up. ANY IDEAS???? Engine runs fine! Just a rough idle
Old 20 Nov 2011, 06:09 pm
Default Re: p0304 misfire code
Could be vacuum leak in the upper manifold around cylinder #4 or cracked head gasket. Also could be a faulty injector.
Old 20 Nov 2011, 07:23 pm
Thanks crewzin, tore the upper manifold apart so I recheck plug wires and then reassembled the manifold. Hopefully that will fix problem. It seem to get rid of the rough idle.
Old 30 Nov 2011, 10:55 pm
check engine light back on 0304 code. Came on when I started car weather changed here got alot cooler from morning till night. Ideas anyone????
Old 01 Feb 2012, 11:47 am
I'm subscribing for any updates. I have a new (to me) 2005 PT GT with the same misfire code, 93K miles. So far it only seems to do it at idle, on-and-off MIL, cold but after 5 minutes of running. I've been told the plugs and wires were changed. I have yet to verify or stick a wrench on it, still in research mode. I have a 3K mile powertrain warranty and want to diagnose any major problems before that runs out. Thanks.
2005 PT GT Convertible
Old 01 Feb 2012, 12:13 pm
cruserdad1976's Avatar
at 93000 was the timimg belt changed???? Im thining id run some Sea Foam and clean the air intake if not that then try a new injector
Old 01 Feb 2012, 07:18 pm
I'd pull a plug and see what condition it is in.
Old 16 Feb 2012, 10:16 am
GA81PEACH19's Avatar
Thumbs up Re: p0304 misfire code
I had the p0304 (and also got a p0300) misfire on cylinder 4 code..went through a lot of time and options to fix it ..I ended up getting a tune up (new wires, plugs and an ignition coil) still getting code, so I ended up getting a new intake gasket under the engine and WAAH LAHH!! NO code, No Light ((Hope this helps))
Old 17 Feb 2012, 12:12 pm
I did fix my problem this is what I did
change plugs,wires,upper intake gaskets,fuel inject cleaning(Valvoline instant oil change),and the light still came on. So I was still #issed off. Then I when for little ride We have nice piece of road here flat and no turnoffs for about a mile @ half .I ran the car up to 80. Took it home reset the code. It hasnt come for two monthes now. My guess is i had a valve not closing right because of carbon build up.
Old 17 Feb 2012, 08:26 pm
Very interesting, will be putting that one in the tool box!
Error Code P0304 Cylinder 4 Misfire Detected WV05Cruiser Tech & Performance Forum 16 23 Feb 2016 10:33 am
p0304 code manzanman Turbo Performance 6 04 Jan 2013 05:56 pm
“Please” does anyone one have any solution to code P0304 KGWilder Tech & Performance Forum 4 15 Dec 2010 01:02 pm
Compression; Continuation of P0304 Misfire duffner Turbo Performance 3 09 Apr 2010 12:39 pm
Error Code P0304 Max Tech & Performance Forum 2 30 Mar 2009 03:46 pm
